- May 23, 2003
- Toronto, Ontario, Canada
Will Zalman 7000CU fit on a 8KDA3+ with a 9800 Pro with VGA Silencer clip on top?
Will the 8KDA3+ fit my Zalman 7000CU. Also I have a modded VGA Silencer, so i've got the blue clip at the top of my 9800 pro that may also touch the Zalman. With my old board (MSI K8N Neo) the Zalman fit, but the blue clip of the VGA was actually touching the Zalman it was so close.
Anyone here using a 8KDA3+ or 8KDA3J with a Zalman 7000? I'll take a dremel to that blue clip of the VGA if needed, so i'm not really worried about that, but the Zalman is big.
EDIT: Just noticed it says on Zalman's website that it fits with all S754 boards...so I guess it fits, but I may have to modify the VGA Silencer bracket.
