- Mar 4, 2010
So my computer has recently started freezing, all the time, very soon after I boot. I will try to do a normal task such as downloading a file or talking on AIM, the computer will try to load the page or whatever and everything will freeze. No task manager, no closing the window, nothing except that the mouse still moves (and even that freezes sometimes). Also my computer runs much slower now, everything takes a long time. Sometimes I can get away with using the computer fine for 10-15 minutes, I've been able to load Half Life 2, etc... but it will freeze soon after that.
This all seemed to start Sunday when I got the "Anti-Virus Soft" Ransom-ware virus. I used recomended .exe to kill it and cleaned it from my system with Malware bytes. I have no idea how I got it because Im on a pretty protected Campus network, and I havent downloaded any sketchy files or been to any weird websites.
I thought I got rid of it but it was back on my computer a few days later, only now it was frozen. I restarted, killed it again and removed it with Malware bytes and Spybot. This is when the constant freezing started.
The one weird thing is that when I start my computer I get this constant error message from Shirasu pad (a note pad app) that fills the screen until I close it. Im pretty sure I deleted that program so I dont know what the deal is. Heres a pic:
I downloaded and installed Avast and got a clean scan.
I cleaned all the dust bunnies off my GPU and CPU fans. The BIOS says the MB and CPU temps are 37C
I ran memtest86 and it said my computer passed.
My Hard Drive is probably only a year and a half old, but I guess that could be failing, what would I do to test that?
I also disconnected the CD Drive, which is older than ****, from power in case that was messing with it somehow. No help.
My other thought was that the GPU (GeForce 8800) is over heating but I cant download the temp test program because my computer freezes. Even so the whole computer is only a little over 3 years old.
Im running out of time an patience. Im considering formatting the drive and installing everything new, but there are a lot of files I dont want to lose, and dont want to spend forever trying to back-up while I dodge freezes.
Any help would be much appreciated. Below I've posted my DxDiag and Hijack this log files, since I dont know if this is virus related. Thanks!
Code:
System Information
Time of this report: 3/4/2010, 11:03:47
Machine name: GERARD
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.091208-2036)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 517MB used, 3420MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GTS
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_042110DE&REV_A2
Display Memory: 640.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.9062 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/16/2009 23:57:00, 5845760 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 8/16/2009 23:57:00, 7729568 bytes
Device Identifier: {D7B71E3E-42D3-11CF-0850-2A2403C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0193
SubSys ID: 0x042110DE
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SoundMAX HD Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_198B&SUBSYS_104381F2&REV_1003
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: ADIHdAud.sys
Driver Version: 5.10.0001.4580 (English)
WHQL Logo'd: n/a
Date and Size: 9/8/2006 11:08:06, 247296 bytes
Other Files:
Driver Provider: AnalogDevices
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x036C
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 13:45:37, 59520 bytes
| Driver: usbd.sys, 8/23/2001 07:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/13/2008 14:18:00, 52480 bytes
| Driver: kbdclass.sys, 4/13/2008 13:39:47, 24576 bytes
+ HID Keyboard Device
| Vendor/Product ID: 0x1532, 0x0101
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/13/2008 13:39:48, 14592 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/13/2008 19:13:20, 40840 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 4/13/2008 13:39:47, 23040 bytes
| Driver: mouhid.sys, 8/17/2001 15:48:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay8 TCP/IP Service Provider: Hamachi - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
FTM (DX7) - Registry: OK, ExeFile: BOS.exe ()
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 0.2 GB
Total Space: 131.1 GB
File System: NTFS
Model: WDC WD3200AAKS-00B3A0
Drive: E:
Free Space: 125.0 GB
Total Space: 174.2 GB
File System: NTFS
Drive: N:
Model: ENUPW Y74H2BK1EN SCSI CdRom Device
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/13/2008 13:40:46, 62976 bytes
System Devices
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&1A82106&0&5878
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 13:46:18, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 13:46:18, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 13:51:25, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 13:51:25, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 08:46:40, 6400 bytes
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_03BC&SUBSYS_00000000&REV_A1\3&2411E6FE&0&11
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_03BB&SUBSYS_00000000&REV_A1\3&2411E6FE&0&38
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/13/2008 13:36:44, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_03BA&SUBSYS_00000000&REV_A1\3&2411E6FE&0&12
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B9&SUBSYS_00000000&REV_A1\3&2411E6FE&0&30
Device ID: PCI\VEN_10DE&DEV_03B7&SUBSYS_00000000&REV_A1\3&2411E6FE&0&18
Device ID: PCI\VEN_10DE&DEV_03B6&SUBSYS_00000000&REV_A1\3&2411E6FE&0&10
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B5&SUBSYS_00000000&REV_A1\3&2411E6FE&0&06
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B4&SUBSYS_00000000&REV_A1\3&2411E6FE&0&07
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B3&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0E
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B2&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0D
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B1&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0C
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B0&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0B
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AF&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0A
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AE&SUBSYS_00000000&REV_A1\3&2411E6FE&0&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AD&SUBSYS_00000000&REV_A1\3&2411E6FE&0&08
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AC&SUBSYS_00000000&REV_A1\3&2411E6FE&0&01
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AB&SUBSYS_00000000&REV_A1\3&2411E6FE&0&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AA&SUBSYS_00000000&REV_A1\3&2411E6FE&0&02
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A9&SUBSYS_00000000&REV_A1\3&2411E6FE&0&03
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A8&SUBSYS_00000000&REV_A2\3&2411E6FE&0&05
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_03A3&SUBSYS_00000000&REV_A2\3&2411E6FE&0&00
Driver: n/a
Name: NVIDIA nForce 590/570/550 Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_CB841043&REV_A2\3&2411E6FE&0&72
Driver: C:\WINDOWS\system32\DRIVERS\nvata.sys, 5.10.2600.0691 (English), 9/21/2006 17:39:16, 105344 bytes
Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 9/21/2006 17:39:20, 363008 bytes
Driver: C:\WINDOWS\system32\idecoiins.dll, 1.00.0000.0001 (English), 9/21/2006 17:39:20, 363008 bytes
Driver: C:\WINDOWS\system32\NVCOI.DLL, 1.00.0000.0035 (English), 9/11/2006 19:27:46, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_CB841043&REV_A2\3&2411E6FE&0&71
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_CB841043&REV_A2\3&2411E6FE&0&70
Device ID: PCI\VEN_10DE&DEV_0378&SUBSYS_00000000&REV_A2\3&2411E6FE&0&B0
Device ID: PCI\VEN_10DE&DEV_0377&SUBSYS_00000000&REV_A2\3&2411E6FE&0&C0
Device ID: PCI\VEN_10DE&DEV_0376&SUBSYS_00000000&REV_A2\3&2411E6FE&0&98
Device ID: PCI\VEN_10DE&DEV_0375&SUBSYS_00000000&REV_A2\3&2411E6FE&0&B8
Device ID: PCI\VEN_10DE&DEV_0374&SUBSYS_00000000&REV_A2\3&2411E6FE&0&A8
Device ID: PCI\VEN_10DE&DEV_0374&SUBSYS_00000000&REV_A2\3&2411E6FE&0&A0
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_CB841043&REV_A2\3&2411E6FE&0&90
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0001.6024 (English), 8/7/2006 18:39:24, 18944 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0002.6024 (English), 8/7/2006 18:39:04, 1104896 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0001.6024 (English), 8/7/2006 18:38:42, 261120 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 8/7/2006 18:37:30, 10240 bytes
Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 8/7/2006 18:37:30, 10240 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0035 (English), 8/4/2006 01:48:54, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_CB841043&REV_A2\3&2411E6FE&0&88
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_10DE&DEV_0371&SUBSYS_81F21043&REV_A2\3&2411E6FE&0&79
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/13/2008 11:36:05, 144384 bytes
Device ID: PCI\VEN_10DE&DEV_0370&SUBSYS_00000000&REV_A2\3&2411E6FE&0&78
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_036E&SUBSYS_CB841043&REV_A1\3&2411E6FE&0&68
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/13/2008 13:40:29, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 13:40:30, 96512 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 07:00:00, 3328 bytes
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036D&SUBSYS_CB841043&REV_A2\3&2411E6FE&0&59
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 13:45:35, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 13:45:36, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/13/2008 19:12:08, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 13:45:37, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/13/2008 19:11:54, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036C&SUBSYS_CB841043&REV_A1\3&2411E6FE&0&58
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/13/2008 13:45:35, 17152 bytes
Device ID: PCI\VEN_10DE&DEV_036A&SUBSYS_CB841043&REV_A2\3&2411E6FE&0&52
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0369&SUBSYS_CB841043&REV_A1\3&2411E6FE&0&48
Driver: n/a
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0368&SUBSYS_CB841043&REV_A2\3&2411E6FE&0&51
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0360&SUBSYS_00000000&REV_A2\3&2411E6FE&0&50
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 13:36:41, 37248 bytes
Name: NVIDIA GeForce 8800 GTS
Device ID: PCI\VEN_10DE&DEV_0193&SUBSYS_042110DE&REV_A2\4&63F8C69&0&0018
Driver: c:\nvidia\displaydriver\190.62\english\NvCplSetupEng.exe, 14.00.0000.0162 (English), 8/16/2009 23:57:00, 19458880 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.9062 (English), 8/16/2009 23:57:00, 7729568 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.9062 (English), 8/16/2009 23:57:00, 5845760 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.9062 (English), 8/16/2009 23:57:00, 868352 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.9062 (English), 8/16/2009 23:57:00, 2002944 bytes
Driver: C:\WINDOWS\system32\nvcuvenc.dll, 6.14.0011.9062 (English), 8/16/2009 23:57:00, 1706528 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0011.9062 (English), 8/16/2009 23:57:00, 2189856 bytes
Driver: C:\WINDOWS\system32\nvdata.bin, 8/16/2009 23:57:00, 1597690 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.9062 (English), 8/16/2009 23:57:00, 10457088 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.06.0002.0057 (English), 8/16/2009 23:57:00, 155648 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.06.0002.0057 (English), 8/16/2009 23:57:00, 155648 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:17 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:17 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:09:20 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:09:19 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:18 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:41 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:02 35328 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 82432 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 2/4/2010 14:05:45 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 2/4/2010 14:05:42 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 2/4/2010 14:05:42 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 2/4/2010 14:05:43 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 2/4/2010 14:05:43 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 2/4/2010 14:05:43 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 2/4/2010 14:05:43 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 2/4/2010 14:05:44 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 2/4/2010 14:05:44 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 2/4/2010 14:05:45 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 2/4/2010 14:05:45 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 2/4/2010 14:05:46 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 2/4/2010 14:05:46 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 2/4/2010 14:05:46 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 2/4/2010 14:05:46 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 2/4/2010 14:05:45 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 2/4/2010 14:05:45 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 2/4/2010 14:05:45 223232 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 07:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 4/13/2008 19:11:56 1028096 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/13/2008 19:12:10 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:11:49 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:11:51 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/13/2008 19:11:52 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:11:56 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:42 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:11:59 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:53 20480 bytes
qasf.dll: 11.00.5705.5043 English Final Retail 8/24/2006 21:30:22 210432 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:03 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:03 279040 bytes
qdvd.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:03 386048 bytes
qedit.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:03 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 12:21:32 733696 bytes
quartz.dll: 6.05.2600.5908 English Final Retail 11/27/2009 12:11:44 1291776 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 03:00:21 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/13/2008 19:12:42 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/13/2008 19:12:42 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/13/2008 19:11:55 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/13/2008 19:11:55 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/13/2008 19:11:55 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/13/2008 19:11:55 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/13/2008 19:11:55 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/13/2008 19:12:42 154624 bytes
mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 04:01:48 204800 bytes
ks.sys: 5.03.2600.5512 English Final Retail 4/13/2008 14:16:36 141056 bytes
ksproxy.ax: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:42 129536 bytes
ksuser.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:56 4096 bytes
stream.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:45:15 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:39:50 5376 bytes
mspqm.sys: 5.01.2600.5512 English Final Retail 4/13/2008 13:39:51 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:39:52 7552 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:39:53 4352 bytes
mstee.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:39:50 5504 bytes
ipsink.ax: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:42 16384 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:42 118272 bytes
ndisip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:46:22 10880 bytes
streamip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:46:22 15232 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:01 1428992 bytes
slip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:46:24 11136 bytes
nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:46:26 85248 bytes
ccdecode.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:46:24 17024 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:42 30208 bytes
msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 12:11:44 17920 bytes
kstvtune.ax: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:42 61952 bytes
ksxbar.ax: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:42 43008 bytes
kswdmcap.ax: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:42 91136 bytes
vfwwdm32.dll: 5.01.2600.5512 English Final Retail 4/13/2008 19:12:08 53760 bytes
wstcodec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:46:24 19200 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:10 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.5512
CC Decoder,0x00200000,2,1,,5.03.2600.5512
WST Codec,0x00200000,1,1,,5.03.2600.5512
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.00.0005.0830
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
VP6 Decompressor,0x00800000,1,1,vp6dec.ax,6.04.0002.0000
Pinnacle Real Media Renderer 2,0x00000000,0,0,,
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0005.2342
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5908
CoreVorbis Audio Decoder,0x00800000,1,1,CoreVorbis.ax,1.01.0000.0079
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0005.2342
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0005.2342
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Mpeg Source,0x00200000,0,0,MpegSplitter.ax,1.00.0000.0005
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5908
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5705.5043
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5908
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5908
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
"MainConcept (Adobe2) AAC Decoder",0x00600000,1,1,ad2daac.ax",
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0002
MONOGRAM AMR Splitter,0x00600000,1,1,mmamr.ax,1.00.0001.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5908
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5908
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5908
CyberLink Video/SP Decoder (PDVD8),0x00800001,2,3,CLVSD.ax,8.01.0000.1608
AVS Video Out,0x00200000,0,1,AVSVideoOutFilter.ax,1.00.0000.0086
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.09.0000.0311
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.0004
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
FLV Splitter,0x00800001,1,1,FLVSplitter.ax,1.00.0000.0005
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5908
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5908
WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.01.0000.0484
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
MONOGRAM AMR Decoder,0x00600000,1,1,mmamr.ax,1.00.0001.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
MONOGRAM Musepack Decoder,0x00600000,1,1,mmmpcdec.ax,0.09.0001.0002
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.08.0122.0018
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.08.0122.0018
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PICVideo M-JPEG 3 DirectShow Decompressor,0x00800001,1,1,pvmjpg30.dll,3.00.0000.0012
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MP4 Splitter,0x00600001,1,1,MP4Splitter.ax,1.00.0000.0004
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
File Source (Monkey Audio),0x00400000,0,1,MonkeySource.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5908
madFlac Decoder,0x00600000,1,1,madFlac.ax,1.08.0000.0000
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5908
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5908
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5908
Haali Video Renderer,0x00200000,1,0,dxr.dll,
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0002
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5705.5043
FLV4 Video Decoder,0x00400000,1,1,FLVSplitter.ax,1.00.0000.0005
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
"MainConcept (Adobe2) AAC Encoder",0x00100000,1,1,ad2eaac.ax",
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.08.0122.0018
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
RealAudio Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0002
Avi Splitter,0x00600001,1,1,avisplitter.ax,1.00.0000.0009
MONOGRAM AMR Encoder,0x00600000,1,1,mmamr.ax,1.00.0001.0000
Pinnacle MP3 Encoder,0x00000000,0,0,,
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
PICVideo M-JPEG 3 DirectShow Compressor,0x00100000,1,1,pvmjpg30.dll,3.00.0000.0012
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.08.0122.0018
AC3Filter,0x40000000,1,1,ac3filter.ax,1.03.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5908
DivX Video Decoder 0004,0x00800000,1,1,DivXDec.ax,8.01.0000.0012
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
MONOGRAM AMR Mux,0x00600000,1,1,mmamr.ax,1.00.0001.0000
DC-Bass Source,0x00400000,0,1,DCBassSource.ax,1.02.0000.0000
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
DTSSource,0x00400000,0,1,dtssource.ax,
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0005.2342
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
VP7 Decompressor,0x00800000,1,1,vp7dec.ax,7.00.0010.0000
MONOGRAM Musepack Splitter,0x00600000,1,1,mmmpcdmx.ax,0.03.0001.0002
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
madFlac Source,0x00600000,0,1,madFlac.ax,1.08.0000.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
FLV Source,0x00600001,0,0,FLVSplitter.ax,1.00.0000.0005
StreamBufferSource,0x00200000,0,0,sbe.dll,
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
Avi Source,0x00600001,0,0,avisplitter.ax,1.00.0000.0009
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5908
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5908
MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.00.0000.0004
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5908
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5908
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5908
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5908
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.5908
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5908
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.01.0000.0323
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.00.0005.2342
Mpeg Splitter,0x00400001,1,1,MpegSplitter.ax,1.00.0000.0005
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0002
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.0004
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5908
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5908
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5908
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Haali Video Sink,0x00200000,1,0,splitter.ax,1.08.0122.0018
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
AC3File,0x00600000,0,1,ac3file.ax,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5908
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5908
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.5512
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0005.2342
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5908
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
DivX® 6.6.1 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.5512
MainConcept DV Codec 2.0.4,0x00200000,1,1,qcap.dll,6.05.2600.5512
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
PICVideo M-JPEG 3 VfW Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V3,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Helix YV12 YUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5908
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5908
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5908
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5908
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5908
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5908
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5908
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5908
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5908
SHARP G.726,0x00200000,1,1,quartz.dll,6.05.2600.5908
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5908
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5908
NCT ALF2 CD,0x00200000,1,1,quartz.dll,6.05.2600.5908
AC-3 ACM Codec,0x00200000,1,1,quartz.dll,6.05.2600.5908
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5908
Audio Capture Sources:
SoundMAX HD Audio,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5908
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5908
Pinnacle Auxiliary Filters:
WDM Streaming Capture Devices:
SoundMAX HD Audio,0x00200000,3,2,,5.03.2600.5512
WDM Streaming Rendering Devices:
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.5512
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
WDM Streaming Communication Transforms:
Audio Renderers:
SoundMAX HD Audio,0x00200000,1,0,quartz.dll,6.05.2600.5908
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5908
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5908
DirectSound: SoundMAX HD Audio,0x00200000,1,0,quartz.dll,6.05.2600.5908
WDM Streaming System Devices:
SoundMAX HD Audio,0x00200000,6,2,,5.03.2600.5512
BDA Receiver Components:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
Code:
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 11:10, on 2010-03-04
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe
C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
C:\Program Files\Bonjour\mDNSResponder.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\WINDOWS\system32\lkcitdl.exe
C:\WINDOWS\system32\lkads.exe
C:\WINDOWS\system32\lktsrv.exe
C:\Program Files\Microsoft LifeCam\MSCamS32.exe
E:\Program Files\National Instruments\MAX\nimxs.exe
E:\Program Files\National Instruments\Shared\Security\nidmsrv.exe
C:\WINDOWS\system32\nisvcloc.exe
E:\Program Files\National Instruments\Shared\Tagger\tagsrv.exe
C:\WINDOWS\system32\PnkBstrA.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\PnkBstrB.exe
C:\Program Files\Spyware Terminator\sp_rsser.exe
C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcAppFlt.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcIp.exe
C:\Program Files\Analog Devices\Core\smax4pnp.exe
C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe
C:\Program Files\HP\hpcoretech\hpcmpmgr.exe
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb10.exe
C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe
C:\PROGRA~1\SPYWAR~1\SpywareTerminatorShield.exe
C:\WINDOWS\system32\RUNDLL32.EXE
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\Analog Devices\SoundMAX\Smax4.exe
C:\PROGRA~1\ALWILS~1\Avast5\avastUI.exe
C:\Program Files\Steam\Steam.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Documents and Settings\Owner\Local Settings\Application Data\Google\Update\1.2.183.17\GoogleCrashHandler.exe
C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
C:\Program Files\Skype\Phone\Skype.exe
C:\Documents and Settings\Owner\Application Data\Dropbox\bin\Dropbox.exe
C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE
C:\Program Files\SolidWorks\SolidWorks\swScheduler\swBOEngine.exe
C:\Program Files\Skype\Plugin Manager\skypePM.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
O2 - BHO: (no name) - {08CECFBA-46E2-4BE3-8727-8550B63717AA} - (no file)
O2 - BHO: Extensions Menu Handler - {3C29D918-10E4-47D8-B2CE-90B0B59481EC} - E:\Program Files\Extensions for Windows\Extensions\Explorer\ExplorerHandler\BandsHelper.dll
O2 - BHO: (no name) - {50F5D716-5510-432E-975B-4532ED902748} - (no file)
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: (no name) - {55443ae6-8434-45df-9f75-d76a06ffe241} - (no file)
O2 - BHO: (no name) - {70F47C65-E944-4C84-BC87-A660F8A3293E} - (no file)
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files\Microsoft Office\Office12\GrooveShellExtensions.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: (no name) - {A2A5628D-1F4A-42C9-A131-2CFFBB231EAA} - (no file)
O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe
O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe"
O4 - HKLM\..\Run: [HP Component Manager] "C:\Program Files\HP\hpcoretech\hpcmpmgr.exe"
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb10.exe
O4 - HKLM\..\Run: [HP Software Update] "C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe"
O4 - HKLM\..\Run: [SpywareTerminator] "C:\PROGRA~1\SPYWAR~1\SpywareTerminatorShield.exe"
O4 - HKLM\..\Run: [ShirusuPad] C:\Documents and Settings\Owner\Desktop\ShirusuPad.exe
O4 - HKLM\..\Run: [LifeCam] "C:\Program Files\Microsoft LifeCam\LifeExp.exe"
O4 - HKLM\..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe
O4 - HKLM\..\Run: [nwiz] C:\Program Files\NVIDIA Corporation\nView\nwiz.exe /install
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QT Lite\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [SoundMax] "C:\Program Files\Analog Devices\SoundMAX\Smax4.exe" /tray
O4 - HKLM\..\Run: [avast5] C:\PROGRA~1\ALWILS~1\Avast5\avastUI.exe /nogui
O4 - HKCU\..\Run: [Steam] "C:\Program Files\Steam\Steam.exe" -silent
O4 - HKCU\..\Run: [Google Update] "C:\Documents and Settings\Owner\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" /c
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O4 - HKCU\..\Run: [DAEMON Tools Pro Agent] "C:\Program Files\DAEMON Tools Pro\DTProAgent.exe" -autorun
O4 - HKCU\..\Run: [Skype] "C:\Program Files\Skype\Phone\Skype.exe" /nosplash /minimized
O4 - Startup: Dropbox.lnk = C:\Documents and Settings\Owner\Application Data\Dropbox\bin\Dropbox.exe
O4 - Startup: OneNote 2007 Screen Clipper and Launcher.lnk = C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE
O4 - Startup: SolidWorks Task Scheduler Engine.lnk = C:\Program Files\SolidWorks\SolidWorks\swScheduler\swBOEngine.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\Office12\REFIEBAR.DLL
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {001EE746-A1F9-460E-80AD-269E088D6A01} (Infotl Control) - http://site.ebrary.com/lib/wpi/support/plugins/ebraryRdr.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1219515847147
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files\Microsoft Office\Office12\GrooveSystemServices.dll
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\COMMON~1\Skype\SKYPE4~1.DLL
O20 - Winlogon Notify: ddcApmNE - ddcApmNE.dll (file missing)
O23 - Service: Lavasoft Ad-Aware Service (aawservice) - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: ForceWare Intelligent Application Manager (IAM) - Unknown owner - C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcAppFlt.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: Lookout Citadel Server (LkCitadelServer) - National Instruments, Inc. - C:\WINDOWS\system32\lkcitdl.exe
O23 - Service: National Instruments PSP Server Locator (lkClassAds) - National Instruments, Inc. - C:\WINDOWS\system32\lkads.exe
O23 - Service: National Instruments Time Synchronization (lkTimeSync) - National Instruments, Inc. - C:\WINDOWS\system32\lktsrv.exe
O23 - Service: NI Configuration Manager (mxssvr) - National Instruments Corporation - E:\Program Files\National Instruments\MAX\nimxs.exe
O23 - Service: National Instruments Domain Service (NIDomainService) - National Instruments, Inc. - E:\Program Files\National Instruments\Shared\Security\nidmsrv.exe
O23 - Service: NILM License Manager - Macrovision Corporation - E:\Program Files\National Instruments\Shared\License Manager\Bin\lmgrd.exe
O23 - Service: NI Service Locator (niSvcLoc) - National Instruments Corp. - C:\WINDOWS\system32\nisvcloc.exe
O23 - Service: National Instruments Variable Engine (NITaggerService) - National Instruments, Inc. - E:\Program Files\National Instruments\Shared\Tagger\tagsrv.exe
O23 - Service: ForceWare IP service (nSvcIp) - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\NetworkAccessManager\bin\nSvcIp.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: PnkBstrA - Unknown owner - C:\WINDOWS\system32\PnkBstrA.exe
O23 - Service: PnkBstrB - Unknown owner - C:\WINDOWS\system32\PnkBstrB.exe
O23 - Service: ServiceLayer - Nokia. - C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
O23 - Service: SolidWorks Licensing Service - SolidWorks - C:\Program Files\Common Files\SolidWorks Shared\Service\SolidWorksLicensing.exe
O23 - Service: Spyware Terminator Realtime Shield Service (sp_rssrv) - Crawler.com - C:\Program Files\Spyware Terminator\sp_rsser.exe
End of file - 11291 bytes
