Win2000 Server Question. PDC???
drdoug26
San Jose, California
Hi all:
I a newbie when it comes to Win2000 Server. I've always used NT4.0 for our office server but finally our main clinic application is compatible with Windows 2000 Server.
I just set it up for the first time and am wondering why there is no option to set it up as a PDC (primary domain controller)?
What is the compatible option that I should use???
Thanks
Drdoug
Xaotic
Very kind Senior
Greensboro NC
The initial install will simply set up a member server. To set it up as a Domain Controller, rather than Member Server, install Active Directory, it will assume certain Master roles in a new AD tree or forest. These roles can be moved later. There is no true PDC in a W2K domain, though there can be a PDC emulator for mixed mode domains.
drdoug26
drdoug26
Active Directory install errors
I've been trying to install ' Active Directory' but I keep getting error messages saying "the network location can not be reached"?
I'm stumped. When I re-formatted and then installed Server 2000, I was hooked up to my home network. Would that have anything to do with this. I've restarted w/ the network cable unpluged rrom the server but got that same message when I tried to install 'active directory'.
Any help would be appreciated.
PS: I also do not need DHCP running for my Router serves up DHCP.
Thanks
Doug
Oni
Oni-ni-Kanab;, Ninja Hippo eater Moderator
St. Catharines, Ontario Canada
drdoug26 said:
Hi all:
Thanks
Drdoug
There is no option for a PDC, because in a Windows2000 network, there are no PDCs. Everything is just a DC. Everything is constantly replicated through Active Directory (regular stuff in 5 minute intervals, security settings/user stuff instantly).
