Win2k peeps with the KA board...
Metaxas
Senior Member
What files do you need on a disk when you do a fresh install of windows 2000? I remember having to have those files, but I've lost the disk and can't remember what files need to be on it, in order to use the RAID array for the first time...
Metaxas (Jun 23, 2001 10:25 p.m.):
The CD that came with my Iwill KK266 had a disk maker on it for this purpose, you might try yours and see.
Thanks it did...however, that did not help though, for some funky reason, well just check this out....
Ok, it hit F6 at the beginning of the install, after booting off the Win2k CD directly. And it will get to the part where, it will ask me to hit S to specify another device, and so I do. I chose the AMI MegaRAID 100 controller for Win2k, and then it procedes to set up the rest of what it has to to run. Ok, well, when it finally gets around to starting Win2k a few seconds, it FREEZES everytime. However, if I don't specifiy a RAID device, it doesn't freeze at that point...somethings funky....
