Win98 Kill Command
ozzlo
Senior whose title will pier
some programs also will work with ctrl+Pause (break)
I need to get rid of that nasty habbit cause it only works sometimes.
Long live CTRL+C
JigPu
Inactive Pokémon Moderator
Vancouver, WA
Alt+F4 is my favorite :)
Though it sounds like you want an actual command that can be run through the command prompt to end a program... If that's the case, and that's the only way to do it, then I don't really know of a solution. I've never discovered a 'kill' command in DOS, and I'm pretty sure MS didn't include one.
JigPu
ArBiTaL 24
There is no spoon
I like alt-f4.
Gives me this warn fuzzy feeling inside.
But not half as much as the reset button on the front :D
su root
Senior Member, --, I teach people how to read your
Ontario, Canada
If the program is still responding, then CTRL-C or CTRL-Break should kill it. If it stops responding, then you can kill it with ALT-F4 it, or click the X button. Doing either should crash the 16bit subsystem that's running the program, effectively killing it.
IHateStupidPPL
IHateStupidPPL
Cookeville/Nashville, TN
I finally found it, its actually kill.exe and it is included on the Windows 98 resource CD. For some reason MS only includes it on the resource CD with 98, but puts in the actual OS and the resource CD with 2k Server. Thanks for the help though.
Yosk
ORR GONNNN
figures kill.exe microsoft was good about to things
LOng Acronyms for thier program names and Obvious program names :)
