(I wasn't sure where to put this. Of the available options, this seemed like it would get the most viewers, so here it is. Sorry for any inconvenience, mod's and admin's. Put it where you like...)
I just installed Win98, and was ready to install Win98se update (I have a one-step win98se install in the mail, but got impatient). I first decided to defrag it, but when I started defrag, I got "not enough memory, close programs and try again" (or similar). This is odd, because there was NOTHING else on the computer -- not even mainboard drivers. I continued playing w/ it, and found I CAN install anything, but the system WON'T run scandisk (in windows), defrag, and Sandra. It does run 3DMark, CacheMan, and scandisk in dos. I've read some things about similar problems, but I didn't see anwsers that really fit this situation; I would like to be a little more sure of the problem before I try to fix it. So here's the pc:
Athlon 650 (100/133, 110/110) and Duron 1.3 (100/100, 100/133, 110/110) - speed made no difference
K7S5A rev 3.1
128mb Corsair XMS pc150 sdram
Quantum Fireball AS 60gb
Radeon 9000 64mb
Pine (Mitsumi?) CD/RW
350w Codgen (just being thorough)
That's it. The only things running in the background are the ati thing and cacheman. Thx for looking.
K7S5A rev 3.1
Radeon 9000 64mb
