Win98SE Startup Problems / Virus Program
Richard1728
NewEngland
Hello Again,
First thanks for all the assistance thus far. I beleive that I am making Progress.
I did as was recommend, I reinstalled my windows programs, and moved my modem card to another PCI slot. The system is working great. The problem is that when I install a virus program I receive startup error messages. I have tried Norton Anti Virus protection and PC-cillin.
Both programs cause the same types of error messages when installed. I have currently uninstalled the virus programs and the system is again working correctly.
What can be done as I know that a system must have virus protection.
Richard
Here is the system,
System is running windows 98SE
ASUS mother board A7V266E VIA KT266A WITH DDR
AMD ATHLON XP 1900
VIDEO CARD GEFORCE 3 TITANIUM 200 64 MEG DDR NVIDIA
HARD DRIVE IBM DESK STAR 75GXP 45 GIG
FAX MODEM LUCENT PCI 56K V90
LOGITECH TRACKMAN MOUSE
MICROSOFT KEYBOARD
RAM DDR /184PIN/ 256 MEG
NOTE THAT I AM NOT OVERCLOCKING THE SYSTEM
Xaotic
Very kind Senior
Greensboro NC
What error messages are you getting? There may be codes that can be researched to determine the source of the problem.
trulyred
ah, maple falls , wa.
did you say your os is win98se? did you also load 98plus? if so there is an anti-virus program already installed it is mcafee virus scan you would have to uninstall it first before you can load some other virus protection software. Mcafee and norton dont get along on the same pc.:D
If you are commited to virus protection on your pc you may want to consider an upgradeable virus protection for a fee service,I have used it for several yrs now and have found it worth while.there are several out there and everyone here will have an opinion on which is the best one so I am hesitant to recommend any one particular service.If you want to know who I usejust pm me.....tr
Cooler666
Disabled
basically just use Norton :bday:
