I dunno what's causing it, only that it only happens when I'm online. Sometimes it doesn't happen and sometimes it does. Basically the song is playing fine then just stops. I look at Winamp and the progress bar is stopped and the picture(the one that is like a live equalizer) is just frozen. It closes fine, but when I reopen it the problem persists. I also notice that sound no longer works on my computer. When I go to restart the computer, the End Task option comes up for Winamp. After I reset, the problem is gone until it comes up later. Anyone know the cause for this? I use WinXP and my ISP is Walmart
(which is AOL except everything says Walmart).
Thanks
Tipycol
Thanks
Tipycol
