windowblinds help
chevro1et
35.012N/ 129.052E
just started messing with it today, can someone help me make my EI menus/ dropdowns/ toolbars look better than this? Cheers!!
[/URL][/IMG]
It really depends on which theme you're using as to what the toolbar buttons, dropdown menus, etc. look like. It appears as if you're running a Vista style theme... try downloading a few different themes, like Ares by Mike Bryant for example (assuming you like the darker themes like Vista)...
http://www.guichamps.com/skins2006.asp?skinid=666
... or Azenis 2 by J J Ying:
http://www.guichamps.com/skins2006.asp?skinid=685
... assuming you're running v 5.x of WB, and your OS is XP.
You can modify a number of different aspects of a theme by first opening the WindowBlinds Configuration, and changing things like "Dialog backgrounds" under Basic Settings, Change Skin Colour under Settings--> Skins, enabling Hyperpaint under Basic Settings--> Performance, etc. You may also want to visit the Stardock Support--> WB forum at WinCustomize here...
http://forums.wincustomize.com/?forumid=167
Hey thanks redduc, like I mentioned, only just started messing w. windowblinds, and am kinda getting the hang of it/ understanding the nuiances. Cheers!!
