Windows 10 from one machine to another, dont have key?
Pierre3400
annnnnnd it's gone
Euroland, Denmark
Hello guys,
I have 2 laptops.
One is a Lenovo that has been through a smokers home, with a Wifi card that works when it feels like it, and the other is a laptop, that works, apart from the it having needed a new HDD/SSD.
The laptop, had run a cracked copy of W7, it did have a legal key for home, but someone wanted Pro on it.
The Lenovo was born with with W8, then put back to W7, and then later upgraded to W10. So its currently running W10, and i would like to "move" this W10 to the laptop, and kill the Lenovo.
Is this possible? The lenovo does not have its key written on the buttom.
trents
Senior Member
I doubt if the Packard Bell would meet the minimum hardware requirements to be able to run Windows 10. They went out of business or were bought out a long time ago.
You would be better off just replacing the wifi adapter on the Lenovo. More than likely you can pick one up off ebay for a few bucks. The are usually very easy to access on older laptops. Usually there's just a panel on the underside with a screw that allows you to get at the RAM and the NIC.
Pierre3400
Pierre3400
annnnnnd it's gone
Euroland, Denmark
It meets the requirements, its a rebranded Acer.
I dont see what this has to do with the question at hand?
Dolk
I once overclocked an Intel
So technically you can, but it is best to have your W10 key that you used to get W10. By this I mean if you didn't out right buy W10, you will need the W7 or W8/8.1 key that came with your product. Either one works just fine.
The best to do is to just remove the HDD/SDD from one system and move it over. Run the clean install feature that is now native to W10. This will remove all files on the main OS disk, but reinstall the OS at the same time. This is when you need the key, as it will un-register since it recognizes new hardware. After this, you are good to use the system. Its pretty clean and I have used this process several times before.
wagex
Chapstick Eating Premium Member
just use a windows 10 key reader, it will search the bios on the current laptop and pull the serial from there.
trents
Senior Member
Because there would be no point in trying to move the OS from the Lenovo to the PB if it wouldn't work anyway. I was just trying to save you some trouble, that's all.
Why don't you just replace the NIC in the Lenovo?
- - - Updated - - -
Yeah, that should work. https://www.lifewire.com/free-product-key-finder-programs-2625119 You could use the media creation tool to create an installer.
Pierre3400
Pierre3400
annnnnnd it's gone
Euroland, Denmark
- - - Updated - - -
Trust me, i have, i picked the same make, model and everything, stuck it in the Lenovo, and BOOM failed to load, due to hardware not being compatable, turns out the NIC i needed was about the same price as a new laptop, sooooo not gonna happen.
I will try key reader. Thanks.
trents
Senior Member
Concerning the NIC, you could also just use a USB Wifi adapter dongle.
