Comodo Firewall 8
https://forums.comodo.com/news-anno...version1511-hotfix-is-released-t113688.0.html
Double click on Setup.exe to install the program > OK > UNCHECK everything > STOP!!
** CLICK ON CUSTOMIZE INSTALLATION here. ** BEFORE CLICKING ON Next
UNCHECK: COMODO GeekBuddy
UNCHECK: COMODO Browser
> Back > Next > STOP!!
** UNCHECK everything **
Do not change DNS settings
Do not change search engine provider to Yahoo!
> Agree and Install
Comodo Firewall will immediately start behaving crazy-restrictive, immediately import any saved configurations if you have them:
Right click on the Comodo icon in the task bar > Open... > Tasks [upper right] > Advanced Tasks > Open Advanced Settings [lower right] > Configuration > Right click on empty white window > Import > Browse to previously saved configuration settings file > Open and wait and allow for it to be imported, then right click on the imported configuration > Activate > Yes > OK > OK
REBOOT.
Otherwise, ignore alerts and immediately start setting your custom configuration:
Right click on the Comodo icon in the task bar > Open... > Tasks [upper right] > Advanced Tasks [lower left] > Open Advanced Settings [lower right] >
General Settings [upper left of the Advanced Settings window] > User Interface >
UNCHECK: Show messages from COMODO Message Center
UNCHECK:*Show welcome screen on startup
UNCHECK: Show desktop widget
UNCHECK: Play sound when an alert is shown
Updates > UNCHECK everything
> Security Settings > File Rating > File Rating Settings > UNCHECK everything
> OK > REBOOT
To temporarily block ALL internet access: Right click on the Comodo icon in the task bar > Advanced View,
Now you can right click on the Comodo icon in the task bar > Firewall > Block All
To see the list of blocked programs:
Tasks > Advanced tasks > Open Advanced Settings > Security Settings > Firewall > Application Rules
Disabling Comodo right-click menu entries such as "Run in COMODO Sandbox":
Enter the following into Start Menu > Run... or Open DOS command box as Administrator and type the following:
regsvr32 /u "%ProgramFiles%\COMODO\COMODO Internet Security\cavshell.dll"
To restore it back into right-click menu, type the following:
regsvr32 "%ProgramFiles%\COMODO\COMODO Internet Security\cavshell.dll"
To temporarily allow everything to go through:
Tasks > Firewall Tasks > Open Advanced Settings > Application Rules >
Right click on empty gray area > Add > Browse > File Group > All Applications >
Copy From > Ruleset > Trusted Application > OK
Make sure the just crated All Applications rule is at the top and
*must* click on OK and have the Application Rules window disappear for this to actually take effect.
Completely remove this rule when finished.
Avira AntiVir Personal 15
Full version location is
http://personal.avira-update.com/package/wks_avira13/win32/en/pecl/avira_free_antivirus_en.exe
Double click on Setup.exe to install the program.
Click on Next, ignoring Avira's warnings to uninstall Comodo Firewall or similar programs which intercept phone-home attempts.
SELECT: Custom
UNCHECK: I want to improve my protection using Avira Protection Cloud
CHECK: I accept the End User License Agreement > Next > Next > STOP!!
!!! IMPORTANT !!! : UNCHECK: Windows Firewall
Otherwise Avira umbrella will integrate with Windows Firewall ON/OFF switch and will be closed even if you are using better third party Firewalls like Comodo Firewall instead of Windows Firewall.
In other words, if you don't UNCHECK: Windows Firewall, you will have to permanently keep Windows Firewall ON for Avira umbrella to be open, even if you use other, better firewalls.
After installation, C:\Program Files (x86)\Avira\AntiVir Desktop\setup.exe controls adding/removing Avira options like Firewall.
CHECK: Confirm manually when sending suspicious files to Avira > Next > Next
Welcome to the Configuration Wizard > Next > Next > STOP!!
Allow the configuration wizard to keep the default Express Setup options. [Do NOT Select All.]
Once again: *DO NOT SELECT ALL* here.
(LEAVE UNCHECKED: Application, Games, Jokes, Programs that violate the private domain) > Next >
UNCHECK: Performs a quick systems scan after the installation > Next > Finish
Run program update, reboot if prompted. Wait for update to install.
UNINSTALL AVIRA ESSENTIALS after installation completes:
Right click on Start Button > Control Panel > Uninstall a program >
If there are two entries:
Avira
Avira Free Antivirus
Avira Essentials is the first entry called "Avira"
Uninstall "Avira" not "Avira Free Antivirus".
Ignore any error messages.
DO NOT ALLOW AVIRA TO UPDATE IMMEDIATELY AFTER UNINSTALLING THIS ENTRY or else Avira Essentials will trick you into reinstalling it.
Once again: DO NOT CLICK ON Accept and Update if prompted immediately after set up finishes. Click on X to close the window > Cancel? > Yes
[This is, again, because Avira may try to get you to reinstall Avira Essentials immediately after you uninstall Avira Essentials.]
Start Avira >
System Scanner (upper left) > Configuration (upper right) >
Always keep this UNCHECKED: Follow symbolic links (on right)
> System Scanner > Scan > Action on detection >
Set for Automatic, Primary action: Ignore [if you want to just scan folders and get a scan report without deleting files or being prompted what to do if virii/malware are found.]
> [bottom line under PC Protection] General > Security >
Disable being notified every time USB drive has an AUTORUN.INF file:
UNCHECK: Block autorun function
> General > Events > Select: Limit size to max. >
> General > Reports > Select: Limit number to max. >
> General > Warnings > UNCHECK Show notice if the virus definition file is out of date
> Apply > First click on OK then > Scheduler [on lower left] > UNCHECK everything.
Set Avira Free Antivirus to Always show in Windows Taskbar.
Also block this Avira messaging popup nag file from accessing the internet, using Comodo Firewall or similar software:
C:\Program Files (x86)\Avira\AntiVir Desktop\ipmgui.exe
or
C:\Program Files\Avira\AntiVir Desktop\ipmgui.exe
To disable Notifier nag screen: Control Panel > View by Category > System and Security first > Administrative Tools [fourth from bottom] > Local Security Policy > Right click on Software Restriction Policies > New Software Restriction Policies SO THAT ADDITIONAL RULES SHOWS UP UNDERNEATH > Right click on Additional Rules > New Path Rule... > Browse... to the path of avnotify.exe default is
C:\Program Files (x86)\Avira\AntiVir Desktop\avnotify.exe
or
C:\Program Files\Avira\AntiVir Desktop\avnotify.exe
> OK > Set the security level to Disallowed > OK
For Windows Home or non-Professional versions, you must reboot into Safe Mode, log in as Administrator, then
go to
and right click on it >
Properties > Security TAB >
[Under Group or usernames] SYSTEM > Edit button > CHECK: Deny for Read & execute > Apply > Yes > OK > OK
Make sure SYSTEM is set to Deny for Read & execute before rebooting.
[Security TAB will only show up on NTFS formatted drives, not FAT32 drives.]
To boot into Safe Mode: Start Menu > Run... > MSCONFIG > Boot TAB >
CHECK: Safe boot > OK
When you finish with Safe Mode, be sure to UNCHECK: Safe boot so you don't reboot into Safe Mode again.
To submit a suspected virus, go to
http://analysis.avira.com/samples/
to upload it.
You can scan multiple drives inside program options: Local Protection > Scanner > CHECK drives you wish to scan. The premium version also offers the option to scan multiple folders here. The free version does not.
Subscription to new virus definitions for this program is renewed automatically when you right click on Avira icon in the task bar > Start update
or download the latest key file from:
http://personal.avira-update.com/package/peclkey/win32/int/hbedv.key
and either copy it to
and restart or go to Help > License management > click on the blue License file link > browse to the new downloaded hbedv.key > Open.
In case of error message:
The procedure entry point
[email protected]@
[email protected]@
[email protected][email protected]@@Z could not be located in the dynamic link library MSVCP90.dll
download and install Microsoft Visual C++ 2008 SP1 Redistributable Package
http://www.microsoft.com/downloads/...FamilyID=a5c84275-3b97-4ab7-a40d-3802b2af5fc2
Manual updates can be downloaded from:
http://dl.antivir.de/down/vdf/ivdf_fusebundle_nt_en.zip
Unzip the downloaded file and copy all the contents to
Using two Antivirus programs at the same time:
It is *not* a good idea to use two Antivirus programs at the same time, they will conflict with each other and most likely cause problems, unless you disable one of them from being active on the system.
Default log file location is
%PROGRAMDATA%\Avira\AntiVir Desktop\LOGFILES
%PROGRAMDATA% stands for
C:\ProgramData\
