- Jan 4, 2024
- Indiana
I have an update to upgrade to 23H2 should I keep my current version of 11 or do the update?
So, wait for MS to get the bugs out is what you are saying.All of the machines in my house have been updated for a while now to some form of 23H2 (its been out for several months). No issues here.
Typically I delay updates for 5 weeks (most it lets you out of the box) and install updates. Works well for me. I think the last time I updated was ~3 weeks ago.
Ok thank you for that info.Maybe I was thinking about the next update, which was postponed because of various issues. I have had the 23H2 for some time on my work laptop (I just checked what I have), and the same version is on my home PC and test rigs (updated a while ago). So, I can only confirm that the 23H2 is fine.
@Flamethrower1972,
The general rule is to wait at least 3-4 weeks, and if you don't see it was removed from the updates list, then it should be fine.
Ok thank you for that info. I have version 21H2.
lol, how? Windows forces updates on you... weird.I have version 21H2.
Indeed. I use it for review OSs and prevent the update service from starting.I assume Win11 still has the registry hack you can do to permanently disable automatic updates. I’d not looked.
