- Aug 17, 2002
Guys I have windows 3.1.1 right here on floppy disk. Think it could run on a athlon system? hehe. i'm assuming the dual processors are already out of the question.
Blueacid said:It would work, but you need DOS as well, windows 3.11 doesn't sit on its own, like Win9x... you installed and ran windows 3.11 under dos, if that makes any sense.
Hence, you need your computer to be running dos 5.0 or above, and only then can you install windows.
BTW, windows 3.11 will just sit a 640x480x16 colours unless you give it better drivers, which i very much DOUBT that you will find!
