Windows 7 install Freeze???
Spazztic_Killer
Northwest Ohio
I install windows 7 all the way then it restarts to finsh updating and run for the first time it freezes?? Any Ideal?
I have all ready tried a copy of dvds discs of the os.
Sulla
Disabled
Can you repeat that part there at the end, I didn't quite understand what happened. Are you clean installing or upgrading?
S
Spazztic_Killer
Northwest Ohio
lol i guess that dont make since lol, I have already tried a couple different copies of windows 7 install discs. And it is always a clean install
Sulla
Disabled
If you have your system overclocked I would return everything to stock until you get everything reinstalled. If this doesn't work or isn't the issue, you should be able to run memtest and see what happens.
redduc900
Inactive Moderator
Portland, OR
Assuming the HDD is connected via the ICH9R controller, make sure the SATA Mode is set to IDE / Enhanced IDE, and not AHCI.
ceyung
Jakarta
ooo...
i had the same problem with you. haha...
i thought it's just me who had this kind of stupid problem. install perfectly but freeze when trying to boot... (tried this all day about 7 times fresh install)
tried with another dvd. works. but when i restart, it freeze again. so now i'm back using xp AGAIN!!
