- Nov 28, 2001
Before I start fiddling with my Windows setup, I'm hopeing someone has had a similar incident and was able to cure the cause.
Upon a fresh restart, once I get to the Windows login screen to input my password, my keyboard does not work properly. I need to press each key multiple times before a character actually appears. The first character in my password needs about 2-3 presses before it'll appear. The 2nd sometimes 12 presses, the 3rd around 4 presses, etc, etc. If I make a mistake and try to use the backspace key, it'll randomly switch between entering some character (I cannot tell what character since the password it hidden) or actually backspacing. This happens everytime I reboot the PC, but it does not occur if I simply logout, or lock the computer.
I thought maybe the keyboard was going bad (ctrl or alt keys getting stuck as it happens while in Windows once in a blue moon) so I tried another USB keyboard, and it exhibits the same exact problem.
I'm running with Logitech drivers as I have a G700 mouse and Wave keyboard, but I do not recall updated drivers causing this problem as I have been running with the same drivers since I reinstalled Windows 7. I can't be sure when it happened though since I restart my PC only after a update during the winter months, but it didn't start to occur till some months after.
Anyone have the same experience?
If not, I know I can goto Safe Mode, but that just disables everything, and I know about disabling startup programs on Windows login, but how can I boot into Windows disabling one driver/program at a time, without having to actually edit the registry or uninstall drivers?
