Windows 7 pin to taskbar?
ps2cho
I switched back to the XP/Vista style bar because it just takes far too long using the default interface. I've used it for about a month now and I got no faster at all.
Once I switched to "small icons" I lost my pinned hotkeys in the taskbar. Even if I drag it in there nothing happens. It just gives the red crossed out circle.
Even if I right click on the icon I want to go to the taskbar, it just "thinks" but nothing happens.
Any ideas?
redduc900
Inactive Moderator
Portland, OR
Save the following w/ a *.reg extension, then double click it to merge it into your registry...
Code:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\lnkfile]
"IsShortcut"=""
