- Jan 18, 2010
- Calgary, Alberta, CANADA!
I'm surprised vista even booted on a P3.
So was I. I put ubuntu on it for him two days later when he realized that just because vista was newer doesn't mean it was faster.
There is a program floating around that will allow you to backup your Vista activation. Then, if you can get hold of a clean Vista installation disk (I think there are legal ways to do that?), you can just install it without activation (choose the edition you had), and restore your activation.I've been hoping he'd let me re-install vista from a clean disk, not the acer one packed full of garbage addons. Doesn't look likely.
XP performance was terrible till we found the ACPI patch for XP, amazing what not being stuck on 166x6 with no cpu fan can do!
the only issue i have with Vista... is Microsoft designed it to be run on beefy machines. It has no scalability. Either you have a beefy machine and it runs fine or you don't and it's a kludgy mess.
Windows 7 scales so much better to the hardware it is installed on. It also doesn't have a lot of the small annoyances that vista had with it's UI design.
XP-Vista took 6 years, but there were some "real" improvements - UAC (I know how everyone hates it, but it's a step in the right direction - mimicking Unix's sudo), power management, DX10, and cosmetic changes.
Vista-7 was ridiculous. 7 is like a patch for Vista, and they sell it for an arm and a leg. It would make sense as a free or very cheap upgrade from Vista.
Next thing you know they will be selling Windows 7.1 with a pink theme for $299. Ultimate edition allows you to change the color.
Nowhere else in the commercial software world do you see people getting away with this.
I don't know. My buddy put vista on his old pentium 3 and it took 10 minutes to boot up. When he had xp on it, it only took about 2.
put windows 98 on that mechine and it will boot in 30 seconds. Its just the way it is. Vista was designed for a minimum of 2gb of RAM to operate correctly. It struggles below that. Vista is fine, its my main os at home on my gaming mechine. I don't even duel boot xp anymore. There is no need to (apart from really old games). Its 64bit, and after getting the graphics drivers sorted just after vistas release, ive been running it since. My reliabiliy index is currently 10 (the maximum). UAC is turned off cause I can't stand that ****, but XP had those stupid popups for executables anyway.
I'm happy with vista, but I love the look and feel of win 7 so I will be upgrading at some point.
Obviously you have never bought a video game
Yeah windows 7 runs great on older hardware, for some reason though it is not a smooth as my Vista 64 bit install though.
As for the GUI, to me so far, it is Vista, with all the things that people complained about Vista that I had never experienced, and am experiencing now LOL
Problems with networking speed and crashing explorer when trying to transfer too many files... simple things that are now completely hidden or need 6+ mouse clicks to get to. That auto maximizing window thing is really, really freaking annoying (going to have to figure out how to disable that), the new task bar hides things too well. I often do not see new IMs from people in messenger, and for some reason even with only one widow open the task bar show 2 open for WLM.
I will continue to use it though, because it is new and I need to learn it inside and out.
Oh and no way is 7 faster than Vista. The RC was... RTM is not.
I never had much trouble with Vista. Ran it on a Pentium D from the first beta, to the final release, and even ran the first beta of 7 on that same Pentium D. None of the OSes were slow or buggy on it.
You think the RC was fast? The Betas were AMAZINGLY fast. It would boot in 45 seconds off of a five year old 7200RPM hard drive, and then never bog down, no matter what you did.
Vista just got bad press. It's better than XP which was better than its predecessors, and so on. It's just progress.
Yep, the same here. Probably some whiners that expected Vista to work perfect on only a 1.0 Ghz and only 512 MB of RAM.
Also probably some whiners that expected it to work with a 1999 with 128 MB of RAM.
