- Nov 22, 2003
- New York City
- Thread Starter
- #41
Don't forget big daddy Christoph =)
Arkaine23 said:Its easy for the linux version... anyone who needs help in that area can just ask Chirswtoph, {PMS}Fishy, or me.....
Heh if I wanted to I could make it display my duallie's temps/voltages, memory/disk/network/cpu useage, music I'm currently listening to, # of new messages in my mailbox, etc.
Mine runs on a linux box's crontab every six hours 45 minutes after the hour (so it catches statsman updates flawlessly). Can't it be task scheduled in windows?
Ven0m said:What do you exactly need for Windows? (that ActiveState)
I know WinAPI and .Net "a bit", so I might help.
rpwinters said:I need a little help. I installed activestate and Sig gen. I was moving right along when it asked for size, so I put in 10k. I setup my unitinfo.txt locations and hit save changes and it gives me invalid entry. How do I fix this? I uninstalled sig gen and figured I would try again after I get some input. Thanks.
Ven0m said:So basically this thing would need to be completely rewritten.
If done in WinAPI, it would be pretty complicated and require lots of time, as it's very low-level API. Http extensions are hard to use and basically I'd have to make simple web browser working on socket level , or use IE (no IE window, but simply its functions).
.Net - should be simple, I'm using self-made sig gen, size of program would be around 20kb, around 5-10kb packet, but it requires .Net Framework then. Most of Windows users have it, as it's in Windows Update, but if not - it's around 20 megs.
13 megs of Active Perl is rather no big deal, but indeed, 13 megs addon to a few kb script looks funny.
Now I'm working on alternative solution (.Net project), and if it works, there will be more details.
