- Sep 21, 2008
Hi.
Last night I did a fresh install of Windows XP. I updated everything, isntalled Norton Internet Security 2006 and scanned my hard drive. No viruses or malware. I didn't do anything after that, I didn't download bad stuff, go to bad websites or anything, that;s all I did.
Whenever I would load file explorer it would take about 10 seconds for the window to appear rather than instantly. Gradually, the longer I leave the computer on, the longer that time gap gets. Now it takes about 1 minutes for file explorer to load.
I did a full reformat (not the quick one) of my local hard drive and reinstalled windows xp, downloading updates and isntalling norton 2006.
The same thing is happening.
Whenever I try to load file explorer, it freezes the entire explorer process so the start menu and its toolbar is completely inoperable for about 2 minutes until, if im lucky, file explorer finally loads otherwise it just hangs for an unbareable amount of time so i kill it with Task Manager and run a new explorer process to restore it.
I try open another window, the same thing happens. After opening about 5 windows I get graphical distortions.
Other graphical glitches include scroll bars not loading and other things not loading properly depending on the program.
When I just downloaded hijackthis just then, the first time I tried opening it I got a low memory error. While in the task manager performance window it shows clearly I should have enough memory.
I had to shut down tons of programs before it would work.
If anyone can give suggestions as to how I can fix this problem they would be much appreciated. It seems no matter what I do after reformatting and reinstalling stuff, I keep getting this memory problem and It's like I'm using 256megs of ram or something. A lot of programs don't load anymore such as winamp and my TV tuner and stuff.
Just in case I've included a hijack this report.
I didnt put this in the hijackthis thread because I dont believe it's a spyware problem/malware problem. I'm just doing it to show you what programs i've got on to help diagnose this problem.
In case anyone wanted to know stuff about my system, I just copied and pasted from a DXDIAG report.
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 1:11:02 PM, on 9/21/2008
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.20861)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Creative\Shared Files\CTAudSvc.exe
C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
C:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe
C:\WINDOWS\system32\RUNDLL32.EXE
C:\Program Files\Creative\Sound Blaster X-Fi\DVDAudio\CTDVDDET.EXE
C:\Program Files\Creative\Shared Files\Module Loader\DLLML.exe
C:\WINDOWS\CTHELPER.EXE
C:\Program Files\VolumeTouch\VolumeTouch.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Messenger\msmsgs.exe
C:\WINDOWS\SYSTEM32\CTXFISPI.EXE
C:\Program Files\Creative\Sound Blaster X-Fi\Entertainment Center\EAXLoadr.exe
C:\Program Files\Creative\ShareDLL\CADI\NotiMan.exe
C:\Program Files\Common Files\Symantec Shared\Security Console\NSCSRVCE.EXE
C:\Program Files\Logitech\GamePanel Software\LCD Manager\lcdmon.exe
C:\Program Files\Logitech\GamePanel Software\LCD Manager\Applets\LCDClock.exe
C:\Program Files\Logitech\GamePanel Software\LCD Manager\Applets\LCDCountdown.exe
C:\Program Files\Logitech\GamePanel Software\LCD Manager\Applets\LCDMedia.exe
C:\Program Files\Logitech\GamePanel Software\LCD Manager\Applets\LCDPop3.exe
C:\Program Files\Logitech\GamePanel Software\G-series Software\LGDCore.exe
C:\Program Files\Logitech\SetPoint\SetPoint.exe
C:\Program Files\Common Files\Logishrd\KHAL2\KHALMNPR.EXE
C:\Program Files\Logitech\SetPoint\LU\LULnchr.exe
C:\Program Files\Logitech\SetPoint\LU\LogitechUpdate.exe
C:\Program Files\Azureus\Azureus.exe
C:\Program Files\LcdStudio\LcdStudio.exe
C:\WINDOWS\system32\PnkBstrA.exe
C:\WINDOWS\system32\PnkBstrB.exe
C:\Program Files\Windows Live\Messenger\usnsvc.exe
C:\WINDOWS\system32\taskmgr.exe
C:\WINDOWS\explorer.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLLoginProxy.exe
C:\Documents and Settings\Ashley\Desktop\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://go.microsoft.com/fwlink/?LinkId=74005
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Norton Internet Security 2006 - {9ECB9560-04F9-4bbc-943D-298DDF1699E1} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
O2 - BHO: NAV Helper - {A8F38D8D-E480-4D52-B7A2-731BB6995FDD} - C:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: Norton Internet Security 2006 - {0B53EAC3-8D69-4b9e-9B19-A37C9A5676A7} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
O3 - Toolbar: Norton AntiVirus - {C4069E3A-68F1-403E-B40E-20066696354B} - C:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe"
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [CTDVDDET] "C:\Program Files\Creative\Sound Blaster X-Fi\DVDAudio\CTDVDDET.EXE"
O4 - HKLM\..\Run: [RCSystem] "C:\Program Files\Creative\Shared Files\Module Loader\DLLML.exe" RCSystem * -Startup
O4 - HKLM\..\Run: [AudioDrvEmulator] "C:\Program Files\Creative\Shared Files\Module Loader\DLLML.exe" -1 AudioDrvEmulator "C:\Program Files\Creative\Shared Files\Module Loader\Audio Emulator\AudDrvEm.dll"
O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
O4 - HKLM\..\Run: [UpdReg] C:\WINDOWS\UpdReg.EXE
O4 - HKLM\..\Run: [VolumeTouch] "C:\Program Files\VolumeTouch\VolumeTouch.exe"
O4 - HKLM\..\Run: [CTxfiHlp] CTXFIHLP.EXE
O4 - HKLM\..\Run: [Launch LCDMon] "C:\Program Files\Logitech\GamePanel Software\LCD Manager\LCDMon.exe"
O4 - HKLM\..\Run: [Launch LGDCore] "C:\Program Files\Logitech\GamePanel Software\G-series Software\LGDCore.exe" /SHOWHIDE
O4 - HKLM\..\Run: [Kernel and Hardware Abstraction Layer] KHALMNPR.EXE
O4 - HKLM\..\Run: [WinampAgent] "C:\Program Files\Winamp\winampa.exe"
O4 - HKLM\..\RunOnce: [LogiSPSetupNeedReboot] rundll32.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\Windows Live\Messenger\MsnMsgr.Exe" /background
O4 - HKUS\S-1-5-19\..\RunOnce: [ShowDeskFix] regsvr32 /s /n /i:u shell32 (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [ShowDeskFix] regsvr32 /s /n /i:u shell32 (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\RunOnce: [ShowDeskFix] regsvr32 /s /n /i:u shell32 (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [ShowDeskFix] regsvr32 /s /n /i:u shell32 (User 'Default user')
O4 - Global Startup: Logitech SetPoint.lnk = C:\Program Files\Logitech\SetPoint\SetPoint.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Runtime Environment 1.6.0) - http://dl8-cdn-01.sun.com/s/ESD44/J...fa/&filename=jinstall-6u7-windows-i586-jc.cab
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
O23 - Service: Symantec Internet Security Password Validation (ccISPwdSvc) - Symantec Corporation - C:\Program Files\Norton Internet Security\ccPwdSvc.exe
O23 - Service: Symantec Network Proxy (ccProxy) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
O23 - Service: COM Host (comHost) - Symantec Corporation - C:\Program Files\Norton Internet Security\comHost.exe
O23 - Service: Creative Audio Engine Licensing Service - Creative Labs - C:\Program Files\Common Files\Creative Labs Shared\Service\CTAELicensing.exe
O23 - Service: Creative Audio Service (CTAudSvcService) - Creative Technology Ltd - C:\Program Files\Creative\Shared Files\CTAudSvc.exe
O23 - Service: Logitech Bluetooth Service (LBTServ) - Logitech, Inc. - C:\Program Files\Common Files\Logishrd\Bluetooth\LBTServ.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: Norton AntiVirus Auto-Protect Service (navapsvc) - Symantec Corporation - C:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
O23 - Service: Norton Protection Center Service (NSCService) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\Security Console\NSCSRVCE.EXE
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: PnkBstrA - Unknown owner - C:\WINDOWS\system32\PnkBstrA.exe
O23 - Service: PnkBstrB - Unknown owner - C:\WINDOWS\system32\PnkBstrB.exe
O23 - Service: Symantec AVScan (SAVScan) - Symantec Corporation - C:\Program Files\Norton Internet Security\Norton AntiVirus\SAVScan.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
O23 - Service: Symantec Core LC - Unknown owner - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
End of file - 10100 bytes
System Information
Time of this report: 9/21/2008, 13:15:28
Machine name: FIREBIRD
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
System Manufacturer: GBT___
System Model: GBTUACPI
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 737MB used, 3201MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 8800 GTS
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_22511682&REV_A2
Display Memory: 640.0 MB
Current Mode: 1440 x 900 (32 bit) (59Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.7519 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 5/16/2008 14:01:00, 6108928 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/16/2008 14:01:00, 6557408 bytes
Sound Devices
Description: SB X-Fi Audio [B000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0005&SUBSYS_00211102&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 6.00.0001.1284 (English)
WHQL Logo'd: n/a
Date and Size: 7/15/2008 18:07:18, 527384 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
