- Jan 23, 2002
- Orlando, FL
A friend of mine wants me to set up a small network in his office.
He has 1 computer that will be a dedicated database server which will be running Windows XP Pro.
He will have either 3 or 4 clients all running windows XP Pro as well.
The questions I have are:
1) Can anybody recommend a good networkable database program, as he is coming over from an old DOS based database program which was running on Novell 3.12 and it will not run on Windows XP.
2) The way I plan to set this up for him is: Wall -> Cable/DSL Modem -> Router/Firewall -> Server -> 5-port Switch -> various clients.
The server would have 2 NICs, one to go out to the router for INet access, the other to run to the uplink of the switch so the clients can get internet access and access to the database program. Please let me know if this is incorrect.
If I do set it up in this way, I know how to set the server up as the go-between for the internet access for the clients using Windows ICS, but will Windows automatically know that is going to be assigning IPs through the switch to the clients? If not, how will I configure this?
3) This is the first time I'm doing this in an office enviorment. I've set up plenty of small home networks and considering this one will be so small im guessing it going to be similar, however id like to know if there is anything i SHOULD know from some of you experienced guys?
4) He would like me to run wires through the walls, now I know that typically office buildings in a downtown enviorment have strict restrictions regarding what can be wired in the walls..can I use regular CAT5 cable or wll i need to use something special? I heard that since typical CAT5 cable is made of polyurethane (sp) it is veeery flammable and should not be used. If that is the case, then what do I use?
And last question, would you recommend going with Windows 2000 Pro over Windows XP Pro, if so, why? Or any other OS for the server/clients.
Thanks a lot guys.
~jeff~
Thanks a lot guys.
~jeff~
