- Jan 23, 2002
- Orlando, FL
OK, I've got the following setup:
DSL Modem -> Linksys 4-port Router -> SMC NIC (Server) -> Intel NIC (Server) -> Dell 16-port Switch -> 3 Computers.
All computers are running Windows XP Pro.
Right now they are set up more like a peer-to-peer network, with file-sharing enabled and all have an IP of 192.168.1.x with a default subnet of 255.255.255.0
What I want to have is to have the one computer (the server) to be set-up like an actual server. I want to be able to install a program like Corel Wordperfect on JUST the server, and have any of the other computers connected able to run this program remotely from their computers. I also want to be able to give and filter i-net access to these other 3 computers through the server.
I have some experience setting up peer-to-peer networks, but not client/server networks. What do i need to do to set this up so that the other 3 computers are logging into the server to access stuff and so that the server will be able to give internet access to the other 3 (do i need to use the IP of the server as the proxy address on the other computers so they can access the web?)
I've got a lot of questions, but I just wanted to get this out, and hopefully get some responses. I need to get this done by Monday, so ANY and ALL advice will be needed and welcomed. =) Thanks guys, I know I can count on you...
~jeff~
~jeff~
