- Jan 5, 2004
- Denver, CO
**Updated 8/19/2005 - 10:30 PST**
The Difference Between 32-Bit and 64-Bit Windows:
Some Windows XP Pro x64 Internet-oriented clients (IE, Outlook, and WMP) are 32-Bit apps so that they can support 32-Bit ActiveX applets (among other things). These will need to be rewritten to support 64-Bit Windows Versions.
32-Bit x86 processors are limited to eight 32-Bit general-purpose registers, eight floating-point registers and eight SSE/SSE2 registers. The 64-Bit CPUs double the number of general-purpose registers to 16 and double the width to 64-Bit. The processors also offer eight new 128-Bit SSE/SSE2 registers for a total of 16.
*Taken from CPU Magazine
The main problem with Windows Xp Pro x64 Edition right now is lack of device driver support. While most 32-Bit software will run under Windows x64, if anything requires a device driver it will function. Before upgrading to x64 you will want to confirm that the hardware and peripherals you own are supported by Windows x64.
Current drivers being tracked by AMD:
Here
Other Common Drivers:
ATI Drivers
AMD CPU Driver
NVIDIA x64 Driver 77.77
NF4 Chipset Drivers 6.66 (AMD)
Intel Nvidia Chipset Drivers 7.13
Creative Sound Blaster Audigy 2 ZS
More Drivers Here
Current software written for Windows XP Pro x64:
Avast AV (Available here)
Stardock WindowBlinds (Available here)
ScienceMark (Available here)
POVRay 3.6 (Available here)
SiSoft Sandra 5 (Available here)
Cinebench (Available here)
Tiny Firewall (Available here)
FarCry 64-Bit Patch (Available here )
ESET NOD32 Anti-Virus (Trial available here)
Firefox 64/Deer Park Alpha 2 (Available here) Like IE 64 theres no working active-x, flash, etc.
Passmark x64 Benchmark (Avalable here)
O&O Defrag V8.0 Beta (Available here)
Please input any known software to be added to this list.
Microsoft claims they are currently tracking over 400 64-Bit applications under development.
Known Hardware Issues:
* A known issue exists with installing Windows x64 onto a RAID array with NF4 based chipsets. The work around for this is to use there F6 drivers.
* Limited drivers for Logitech peripherals. (Setpoint drivers and Joystick/Gamepad software)
Please input any known hardware problems to be added to this list.
Known Software Issues:
* Aquamark3
* Daemon Tools
* Winrar Shells (3.5 Beta has working Shell Extensions)
* Alcohol 120%
* Diskeeper Defragmenter Home & Pro
* RegSeeker (Causes instant BSOD after cleaning, unsure on other Registry Cleaners).
* WinFlash
Look here for more info on applications (I do not have confirmation on these, so just use this as a general guide)
Please input any known Software problems to be added to this list.
Comparison of Windows XP Pro 32-Bit vs. XP Pro 64-Bit:
Here
Download 180-Day Trial Version:
Here
Buy Here
FAQ:
Q: Is installing Windows XP Pro x64 Edition any different than Windows XP Pro?
A: No, there is no difference with installing the latest version of Windows.
Q: Will ***** hardware work with Windows XP Pro x64 Edition?
A: Please check this list out before you install Windows x64. Also check with your manufacturers website for the latest driver versions.
Q: Can i still upgrade my copy of Windows XP Pro?
A: Yes! According to this link you have until Aug 31, 2005 to upgrade.
Q: Can i install Windows XP Pro x64 Edition over top of my current 32-Bit XP?
A: No! Windows XP x64 requires system drivers, as such 32-Bit system drivers will not work with Windows XP Pro x64 Edition.
Q: Does Windows XP Pro x64 Edition look different than Windows XP 32-Bit?
A: Not really. The only obvious changes to Windows x64 is the desktop background, there is now a "Program Files" folder for 64-Bit applications and a "Program Files (x86)" folder for 32-Bit applications. In task manager it will put a *32 next to any task that is running in 32-Bit mode.
Q: Does Windows XP Pro x64 Edition feel any different than Windows XP Pro 32-Bit?
A: It feels very similar to Windows XP 32-Bit, i have not noticed any difference in daily performance.
Q: Will my 32-Bit software still run under Windows XP Pro x64 Edition?
A: Please refer to known software issues above to see if your program does in fact work/not work. As long as the program does not require a device driver it should function properly under Windows x64.
Q: Do 32-Bit applications feel faster in Windows x64?
A: No. 32-Bit applications can actually run slightly slower under Windows x64. If you are using over 2GB of memory it can potentially run faster.
Q: Can i install Service Pack 2 for Windows XP Pro x64 Edition?
A: No. Windows XP Pro x64 Edition is based on the Server 2003 SP1 Kernal.
Q: Do 16-Bit and DOS applications run under Windows XP Pro x64 Edition?
A: No. Windows x64 no longer supports 16-Bit and DOS.
Q: Should i upgrade to Windows XP Pro x64 Edition?
A: I would suggest you read this post fully before making any decisions. I would also advise you to try the Trial Version first to ensure all devices/software work on your system.
Q: Can i upgrade to the full retail version from the Trial Version?
A: To the best of my knowledge you will need to completly reinstall the full version losing all saved information.
Q: Can i dual boot with Windows XP Pro 32-Bit?
A: Yes! This is what i have been doing for the past few weeks and it works great. The only known issue is you can not access RAID arrays from the opposite OS as they require device drivers.
Q: Does Windows XP Pro x64 Edition have automatic update?
A: Yes. Although there are problems with ActiveX automatic updates do work on Windows x64.
Q: Sucka, do you personally like Windows XP Pro x64 Edition?
A: Yes! All of my hardware is supported by Windows x64, and it looks/feels the same as Windows XP Pro 32-Bit so why not use it!
This is a work in progress thread. Please feel free to submit anything to be added to this thread.
Check back often as i will keep this post updated.
Code:
[COLOR=Yellow][B]32-Bit Windows XP Pro[/B] [B]64-Bit Windows XP Pro[/B][/COLOR]
Processors Supported 1 or 2 1 or 2
Maximum Physical RAM 4GB 128GB
Total Virtual Address Space
(Based on single process) 4GB 16TB
Virtual Address Space Per
32-Bit Process 2GB (3GB if booted 4GB(if compiled with "/large
with "/3GB" switch) addressaware";2GB otherwise)
64-Bit Process N/A 8TB
Supports "No Execute(AMD)"
"Execute Disable(Intel) Bit" No Yes
OS Kernal Windows XP Windows Server 2003 SP1
Kernal-Mode Device Driver 16-Bit and 32-Bit 64-Bit
Applications Support DOS,16-Bit,32-Bit 32-Bit, Extended 32-Bit, 64-Bit
DLL Support 32-Bit Only 64-Bit Only;32-Bit ActiveX applets
will not run under WinXP Pro x64*
Here
ATI Drivers
AMD CPU Driver
More Drivers Here
* Aquamark3
* Daemon Tools
* Alcohol 120%
* WinFlash
Here
Here
Buy Here
FAQ:
