Hey guys, I know it's pretty common for people to leave windows open in the winter to coax some cold air into their computer rooms to help bring temps down, and I've also heard of a few instances of ducting the cold air from outside to the computer's intake fans. I don't really have the ability to do that kind of ducting (space concerns, and in the short term materials too, I suppose) and I can't just let the whole room get cold, since I live in a dorm with two roommates. Besides that, leaving the window wide open right now isn't getting the room that cold (it was in the upper 40s today and my ambient temps were like 25-26C), although being in Ithaca it sure will be cold later.
Anyway, here's the solution that I've come up with: I want to put my computer on the windowsill and duct the cold air from outside to the intake with a couple pieces of cardboard (readily available). I'm not going to try to describe the windowsill, but just trust me that I can set it there without it being precarious. For precaution against weather I intend to tape up a plastic garbage bag to the part of the screen that will be directly in front of the opening to the duct, as well as another garbage bag (and maybe some cardboard too, although I think the garbage bag is really the key thing here) to the side of the case that will be towards the open window as well.
A second way to describe what I'm doing would be this. I'll open the window to the height of the highest intake fan on the front of my computer. I'll put a plastic protective layer over the half of the open portion that my computer will be blocking, as well as a protective layer on the screen everywhere that the computer won't be blocking. Because it gets windy up here on the 5th floor, I'll leave a decent amount of overlap here. Then I'll simply build a structure out of cardboard (and duct tape, yay duct tape! ) that will basically serve to keep the cold air from going into the rest of the room. Basically one wall of this structure will be the intake fans of the computer.
Alright so I hope between those two explanations something clicked and you can visualize what I'm doing. If the whole windowsill idea is still throwing you just imagine the bottom of the window is on the floor. Seriously this is a beast windowsill. If it's still not clear I can sketch something up.
The reason I've come to OCF with this detailed concept is because I want to know what you guys think of the safety of the idea. Am I just asking rain or snow to be pulled into my computer? I have dust filters, and will probably rig up some stockings in addition to those (just so it's easier to clean, getting at my dust filters is a pain. But hey the stockings are extra protection too!). I intend to make this quite secure, but honestly my only resources are thin cardboard, plastic garbage bags, and duct tape. I really don't expect any problems, how much water could get in? Even with significantly reduced precautions?
But what do you guys think?
The only additional protection I can think of is I can insert something perpendicular to the screen to block part of the gap between the protective layer on the computer side and protective layer on the screen side. I wouldn't expect to see a reduction in airflow (I'd still leave it wide enough open for air to get through) but I guess this could cut the angle off for things like droplets of water to get closer to my fans. I think this would be entering the psychotic zone though.
I don't mean to be pushy, but I need replies kinda fast. Gotta get this rigged up before I leave for thanksgiving or my roommate is likely to close the window and turn on the heat, choking my poor folding machine . No pressure though . Thanks for the help, OCF rocks!
