Thanks for all the extra replies.
Mr.Guvernment: I dont plan to OC either machine.
I just put the PC together and for some reason Windows XP isnt loading. The specifics are
1.4 Duron
60 GB Seagate HD
ECS SiS 735 Chipset Motherboard K7S5A PRO
2x 256 Kingston value PC2100
Asus 52x Cd-rom
Mitsumi Floppy
RaidMax 350w Case
Chaintech GeForce4 MX440
The HD is from an old computer of my Dad's with WinXP Home already installed. After putting it in and turning the PC on, the BIOS screen and all that stuff comes on fine but when its time for Windows to load, nothing happens. When I restarted once more, the usual message of "Windows XP didnt start properly, which mode would you like to run it in" came up so I picked safe mode. Once again, Windows did not load. I took the HD out and put it in my 2.4C PC and it worked fine. What could be wrong?
Are you putting it in your 2.4C as the boot drive? I'm thinking that Windows is detecting that the HD is a new machine. It will probably have to be formatted and reinstalled before it will work properly.
I see. =/ Is there no way around that? My dad has a lot of files on there and its going to take many CDRW exchanges to move the files.
Not that I know of. You might try asking over in MS Operating Systems, they might have an answer for you.
And so I came here. Can anyone help me out or is that all I can do?
