OCn00b said:Would THIS work?
If that will work, would a fortron 350w be enough to run 2 boards both running XP2400+ cpu's doing nothing but folding? It's doubtful they would be overclocked but should I choose to, would the 350w be enough to handle a mild overclock on both cpu's?
OCn00b said:Are their any premade wire harnesses that you can plug into the motherboard connector on a psu that splits it to run two boards? I read the how-to but it would be alot easier if there were premade deals that would do the same thing.
nut581 said:
I just read the duallie (SMP) guide for AMD, and it recommends 500W and above PSU for stable power .. having said that, 350W to run 2x2Ghz (2400+) seems kinda close to the edge .. I will have exact same PSU coming my way .. so if this works fine on your farm, let me know and I'll do the same
