- Nov 24, 2011
last week a costume wire i made starting to fail, fixed it moving that wire to a lower current load (1 fan vs 2 fan load), this should work till that wire suffers the same fate
what wire size should i use for the tiny plugs i always have issues cause the instillation is too thick to fit in the plug's housing
i know the pins are supposed to be good for up to 22 awg wire, i recall having issues using 24awg wire i have, i think it has issues cause it was 24x2 bonded is it did not tear perfectly even
does anyone have a link to some wire that would be good for thiss? preferably black wire
