wiretrick??
moosedick
I have an asus cusl2-c mobo and was on cusl2c.com and heard about a wiretrick. i wanted to know what this is? also, is there a way to get more vcore options above 1.95? thanks
check out hard ocp.com in the articles section remember if you do this only go a little higher then your default CV or you may go to high and fry something if your CV is 1.7 then wire it to a default of 1.9 and this will work I went to high and it changed nothing in BIOS at all need any help look at other post with voltage problems and some have a direct link to the page.
