Wont restart
RJ
Michigan ,USA
When I up the voltage on the vcore past the default 1.79v it wont restart. I have to completely shut the system down to reboot both on win2k and ME.Any ideas?
terisk (Jul 11, 2001 09:44 p.m.):
I am curious...
What kind of power supply you running with?
I dont know what brand but its 300w and it came with my enlight 7237 case
I just installed a Enermax 431w psu and it still does the same thing any other idea? oh also I upgraded the memory also to pc166 Kingmax.
The Benzine Ring (Jul 16, 2001 01:21 p.m.):
Are you sure that mb can support that memory? I would double check.
It's suppose to handle it but it had the same prob with pc133 also
