FEATURED Woomack's memory test list
V I P E R
Hey Woomack,
Do you plan to test the new G.SKILL TridentZ F4-3200C14Q-32GTZ 14-14-14-34 kits? I want to try them in my X99 platform, but I'm unsure at the moment.
W
Woomack
Benching Team Leader
If I won't get review sample then I'm not planning to test this memory. Right now I have 2x8GB 3600 16-16-16 kit which should be on similar IC but I'm not planning to test it on X99. X99 in most cases is limited to 3200-3333 max. Looking at other kits on new Samsungs I can only tell you that at 3200 it should run at CL12-13 on low voltage. Pretty much best stuff around right now.
W
Woomack
I just wanted to say that soon you can expect 3 reviews of new or less popular DDR4 memory kits. There will be something from G.Skill, Mushkin and maybe something more.
I'm also trying to make comparison on DDR4 SODIMM but so far manufacturers don't want to send anything for review and it's hard to make any comparison based on 1 memory kit ;) ... will see, I guess it's matter of time as high end Skylake laptops are getting more popular. It's probably related to higher availability as laptop manufacturers are finally starting to replace older series.
Silver_Pharaoh
Likes the big ones n00b Member
If only I could use DDR4 :(
Thanks for the reviews either way Woomack! :)
Now going to catch up on your SSD reviews
EDIT: Your Crucial MX200 review link is dead, this one works though :)
W
Woomack
Yes, there were changes on the server and some of the articles have slightly different address now. I'm trying to correct that on the review list but sometimes I miss something.
You can take a look at Mushkin Striker SSD review on the overclockers.com front page. I have to add it later to the list.
W
Woomack
I already added 4 memory kits to the list. Reviews should be added soon or I already started threads which will be updated in next days.
Patriot Viper 4 2x4GB DDR4-3200 16-16-16
Patriot Viper Elite 2x4GB DDR4-2800 16-18-18
G.Skill Trident Z 2x8GB 3000 14-14-14
G.Skill Trident Z 2x8GB 3600 16-16-16
V I P E R
Hey Woomack, sorry to post in your thread, but I've got 2 kits of G.SKILL TridentZ F4-3200C14Q-32GTZ 14-14-14-34. I'm happy with 24/7 results on X99.
BEST AIDA 64GB:
MEMTEST 32GB 24/7 1,375 volts
W
Woomack
nice :thup: , no problem to post in this thread if you have something to show :)
I was testing 3000 C14 and 3600 C16 on ASRock X99 and it was working quite stable @3466 13-13-13. Don't remember exactly what voltage but wasn't much higher than default.
These chips are working great on everything.
V I P E R
On RVE I can't get stable 13/13/13 @ 3200 until 1,43 volts, but I'll continue testing. If you have some screenshots of your setting it will help a lot.
W
Woomack
Yesterday I added forum review based on HyperX Predator 2x8GB DDR4-3333 memory kit. It's a new series and I see that some motherboards have issues to work at higher frequency with this memory or run at XMP/3333. I already received quick response from ASRock that they will check this issue and probably will release new BIOS soon. Till then I posted results at DDR4-3200 and first XMP profile @3000.
Leegit
Kansas
Request for Review:
Corsair Vengeance DDR4 - 2 x 8GB 3200 MHz
Kingston HyperX Fury DDR4 - 2 x 4GB 2400 MHz
