WOOOOOOT! Finally hit 13k on 3Dmark w/ my TI4200!!
maxima88
maxima88
Thanks. I actually started really trying last night and ran it about 10x w/ all sorts of different Opengl and directdraw/direct3d settings.
Have to run my RAM at CAS2-2-2-5-1 to get higher scores.
After my 2nd run this evening, I made it.
maxima88
maxima88
Lazlo Panaflex said:
how are you cooling your ram? i cant even seem to overclock my ram past 500! on my evga! and i have heatsinks (cheap ones) on it.
I'm using the stock fan that came with the vid card.
Although I have a 120mm fan on my side cover blowing directly onto the vid card and my room temp right now is 18c. That's helps cool my vid card tremendously.
fuzzba11
in the garage
My MSI 4200 is also quite happy to overclock through the roof, straight out of the box, now I just need to RMA my 1800+ so I can play with the upper limits...
