- Feb 2, 2002
- Wheaton, IL
I finally got my parts from NewEGG.com. I highly recommend
them if you don't have any local stores to give you some
OC Goodness with some High End Parts.
Anywho, I recently got this VP-6 with a pair of PIII 933s
and some OCZ PC-150 Gen 2 or 3. But with one Alpha
something aruther with a Delta that kept sliding off the
processor die cause it was so damn heavy, and one "stock"
PIII heatsink with a Delta black label wannabe that had a
bum clip that barely held the heat sink on.
So I ordered a pair of these on the recommendation of
Hoot from here in the forums:
http://www.dynatron-corp.com/proddetail.asp?cid=6&sku=DY1206BH-625
Without even a voltage increase on ANYTHING, I'm running
(2) 256MB sticks, and now pushing 155Mhz FSB with all
memory timings on FAST and everything else cranked!
I can push the memory one notch higher, but I have to run a
single stick of 256 to do that, and right now I'm using this
system for some video editing-I need the memory.
I'd say that's a pretty damn bad assed board and memory
combo, and these Dynatron heat sinks at $18 each are the
*BEST* OC upgrade bang for the buck I've had yet!!
Look out top 10!
Look out top 10!
