lol, don't be so soft use atitool to scan for artifacts and OC the bejesus out of itgeeman74 said:i got the oem power color
just ran 3d mark 05 got good fps but card got bit hot so stopped the bench
only ocd 20mhz on the core
yes it was from monarch, and man have they jacked up the pricesuperdaveviii said:Is that the OEM Connect3d from Monarch? That would be really sweet if it was a BBA ... mine will hopefully be here by the end of the week =D
Heh... sure thing. Only reason why im not getting a PCI-E card is because im hording my money for E0s which should be out in a matter of weeks.bobmanfoo said:Sentential,(i think im the only one that gets your name right )
im broke now too... just picked up a 5mp digicam with a macro lens and telescopic lens yesterday too... nothing more till summer, and if anyone sees me posting questions about something i want to get, please be a bud and convince me not to....
thanks for the explanation, I just got my X800XL today and found the little adaptor cable like you saidbobmanfoo said:shiyan,
the power connector is a pci-e connector, the cards ship with molex-to-pci-e plug, the plug has 2 grounds and a 12v line in it although there it is a 6pin plug
what are your idle and load temps? just wondering cause i think im just going to put my gpu block on it from the get go.... too lazy to test with stock hsf then rip my rig apart again to put the block ongeeman74 said:couldnt keep my finger on the bar on the top so thought it was a bit hot thinkin of puttin sum ram sinks on it
or adding my water block but thats not gonna cool the ram
