- Nov 4, 2002
- NJ
CPU - $219 + $0 shiping - TIMES TWO!
AMD Athlon MP 2200 1.8GHz PROCESSOR CPU - OEM
***(DUALING)***
Motherboard - $225 +$12 Shiping
MSI K7D Master-L (MS-6501-030) AMD760MPX Dual Athlon 266MHz ATX MOTHERBOARD With Onboard LAN- RETAIL
RAM - $115 + $0 for shipping
Kingmax 512MB DDR RAM PC-2100 CL2.5
VidCard - $233 + $0 for shiping
ALBATRON GeForce 4 TI4600 (NVIDIA GeForce4 TI4600 GPU), 128MB DDR. TV-Out. w/ DVI adaptor
Case - About $130 with Power suplie
Heat sink - $51.00 +$5.00 shiping - TIMES TWO!
Thermal Tek SLK800 with 80mm Sunon Fan
DVD/CD - $42.00
LITE-ON LTD-166S16X DVD ROM Drive - Retail48X CD-ROM
HardDrive - $145 + $0 shiping Shiping
WD WESTERN DIGITAL EIDE HARD DRIVE 120GB 7200RPM MODEL # WD1200BB -Caviar OEM, DRIVE ONLY
Sound Card - $84 + $4 for shiping
Creative Labs Sound Blaster Audigy Gamer
NIC card - Onboard MB
KB + Mouse - About $50bux
Total = $1,585
Is it worth the price? Hopefully this machine is easily overclockable, as I'm having a less than enjoyable time trying to overclock my Sony Vaio (http://forum.oc-forums.com/vb/showthread.php?s=&threadid=136696).
Any tips on the machine? I'm trying to get the Alienware Antec(?) case with a 500 watt power supply with it. It's pretty good to my eye, but what about to yours?
As advertising isn't allowed here, if you want to know where I'm buying this stuff from I'll tell you via email or AIM (Jag22487).
I just want help knowing if I can get a better machine for less, and where from. Also, if the stated parts won't work optimally together, what replacements should I get?
Thanks for the input!!
***(DUALING)***
DVD/CD - $42.00
Total = $1,585
