worth it?
Koenraad
Belgium
I have just seen an add for an unlocked AMD Athlon XP 1700+ JIUHB stepping. it's 72 euro. is this a cpu worth buying to have some fun with o/c ing. or would i not get very far?
Chaos Snake
Washington State
If the Processor your wanting to replace is the one in your sig and you have the cash I'd say go for it. The I droped one in my KT-400 board and these were the results I got.
2 xp test
I'd say with a Kt-333 baord and the ram you have you should get pretty close to these results.
K
Koenraad
Belgium
yes, thats the on i would like to replace. With this 1700 one i will have some fun then? anyway if i skrew it up i still have my old one.
My birthday is comming up soon, expecting to get some cash...:D
K
Koenraad
Belgium
modenaf1 said:
happy bday in advance :bday: try to get the DLT3C, and, dont chip the core on your bday :)
thanks
i m going to give it a try
o, does it actualy say DLT3C in the chip itself?
wannaoc
Buried in UPS packages
I wouldn't buy it for "being unlocked" as all those are unlocked I'm pretty sure. I would check around first before buying on prices, you may find it cheaper.
K
Koenraad
Belgium
I wanted to go and get the XP 1700+. so i phoned them first. They told me they ran out of stock and proposed me a 1800 instead with the same stepping and for the same price. is it ok or is there a snagg?
correct me if i'm wrong: in theory i will be able to oc the chip just as fast, only it will be oc'ed less.
