wot tweak prog for a gforce3
quark
south wales uk
i just got my gf3 today and it was an oem version just came with nvidia drivers I was wondering wot you guys are using to tweak yours with, cheers.
I use the 1200 or 1290 drivers with coolbits.
Don't change anything (tried, no effect as you read in the other post) but the GPU/memory speeds.
quark (Jul 20, 2001 07:48 p.m.):
cheers Ill do that, by the way did you check wot i said?
Yep, FSAA is disabled when 3Dmark says it is. I manually disabled it but there was no change.
