- May 5, 2012
Hello this is my first build / first time posting on this site(hope I'm posting in the right section sorry to any MOD if I have) I have tried searching but I havent seen a similar build like mine so far...
Lan party build
Case: A30 thermaltake http://www.thermaltakeusa.com/Product.aspx?C=1466&ID=1989#Tab1
Drive: Sony OEM SATA 24x http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031&Tpk=sony oem sata drive
MOBO: asus M4A88T-M (microATX) http://www.asus.com/Motherboards/AMD_AM3/M4A88TM/
CPU: AMD 1100T BE
RAM: Crucial Ballistix (2 sticks 8gb DDR3-1600MHz) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1412141&CatId=4534
GPU: sapphire 6770 vapor-x oc edition 860mhz http://www.newegg.com/Product/Product.aspx?Item=N82E16814102937&Tpk=6770 sapphire
HDD: western digital IDE (its what i have atm, looking at it but cant tell if its 5400 or 7200rpm and oem windows 7 already on it, set up before psu gave out)
PSU: COOLMAX ZX Series ZX-600 600W http://www.newegg.com/Product/Product.aspx?Item=N82E16817159125
the PSU has died after 2 1/2 weeks of moderate use and nothing OC'ed. I have rma'ed it awaiting to hear back from newegg, which is why im asking if 600w 80+ silver is enough for my build, or should i go higher?
TY in advance,
ps. I used 3 different PSU calculators but not sure how accurate they are, and not doing sli/x-fire with this build
ps#2 i have checked with another psu and thankfully nothing was damaged
Lan party build
CPU: AMD 1100T BE
TY in advance,
zombieking
