I plan on sealing the mobo/socket with the silicon sealant they use in bathrooms, and also use foam to keep out the air. If you only use sealant, the air in the spaces between Waterblock/HSF and cpu will get cold and it's moisture will condense onto the cpu.
Use foam as well as sealant for better protection.
