When I installed a YS Tech TMD fan on the CPU heatsink and plugged it into the cpu fan header on the motherboard, the fan did not work properly. It was reluctant to spin and would stall often. Then the power supply began to stink like burning electronics. After replacing it with a new 350w Fortron, the motherboard would no longer power fans attached to any of the fan headers.
It is an Asus A78NX Deluxe motherboard (nforce2). Is there some incompatibility with the TMD fan?
Should I try to RMA the motherboard? I got it from newegg 8 months ago.
