Would this be a good Idea?
Mr. $T$
I got a 10 gallon fishtank and some other supplies I also have a Water block. Would it be a good Idea to skip out on the raditor and use the fish tank as the water source?
frostmeister
Good old UK
You could use the fishtank as the water source and the radiator. All you need to do is mount a fan on the fishtank to blow over the water and evaporate it.
masitti
Colorado
Sniperboy said:
It's a fishtank, so you wouldn't have to refill very often.
I don't think it matters, it will try to evaperate as much as it can - you'll still have to refill it often, although prolly not as often as bong users and such. :)
Nico3k
CA
actually yes that is a very good alternative. ive seen people do that and they get some very nice tempratures even without any fans or anything over the tank.
go for it
