- Mar 19, 2001
2 years ago, when I replaced my pentium 100 with my curent k6 2 333 asus motherboard, I kept the original case. It was more than a few years old, and the new motherboard did not necessarily line up in the same bolt pattern as the case...
I removed the metal posts that were in the way. screwed the motherboard in, and noticed it was a bit wobbly... enough to let it ground out on the case...
So bright idea: I took the thin piece of foam rubber that covered the motherboard in the box and put it underneath the board in the case. No more grounding problem, it was stable, and I was happy...
2 years later, I'm wondering if it was such a bright idea to do that... Even though the board has lasted me this long, and it does not appear it wants to last me too much longer, I am thinking of doing the same thing on my next machine...
I'm asking, do you think it was a bad idea, a good idea, or what?
Would it contribute to over heating problems with a 1 ghz thunderbird?
Would it contribute to a potential static electricity build up?
I don't really think that is the case, as there is nothing for it to build a charge against...
Ideas are appreciated...
Thanks
Scorpion12
Thanks
Scorpion12
