Ebola said:
yes. try david's overfoldix. you dont need a hardrive to run it.
It needs a CDROM drive, but thats it. And it isn't quite perfect yet but if you want to give it a shot, just let me know. Its a 3MB CD image that you will need to burn to disk. You will need a permenant net connection and:
- an IP address
- a net gateway IP address (the machine through which to access the net
- the name of a DNS server that is reachable by your machine.
PM or Email me if you want to give it a shot - I'd be glad of any help in testing it.
About the 133MHz rig? Try it. Overclock to at least 166MHz if possible. Give it a shot and if it works, perfect. If it doesn't then its no big loss.
Another idea is, if your rig has a BBA5 or something as pathetic and the P133 gets a ProteinA, you can swap the work.
