Well, Right now I dont really have any means of taking a picture and posting it for you guys. Besides, It's nothing to pretty looking anyway.
The only thing that is in the case is the waterblock. The radiator is hanging underneath my desk with a 90mm fan on it for now (stuck on with 2 rubber bands). And the pump is sitting on top of my subwoofer undernieth the desk.
I had to keep everything outside of the case cause when I put it in the temps were quit a bit higher. So When I get around to it I will have to build a box for the radiator and pump.
It's nice not having to worry about a reservoir. Keeps a a lot simpler! Takes up a lot less space without it.
As far as having a special PSU for the pelt. No, All I'm using is my 431w Enermax that runs the rest of my system. So the pelt is running at 12v's.
And as far as the temps I posted. I guess I was a little premature on that. That was this morning when it was a lot cooler in the house. Now it's around 75 degrees outside and warm in the house so the temps went up a bit. Now they are about 13.5c under full load, and around 6c at idle. But thats still not bad. I dont think so anyway. I think when I get one or two 120mm fans on the radiator it will come down even more.
All and all I'm pretty happy with the whole thing.
