wowexec and winold.mod processes ?
s[H]sIkuA
is this some kind of spyware??
it start everytime and dont use memory and on the "CPU" section it shows nothing about this two process
weird
Wow Pinky i just did a search and found this. Thanks a ton. That should be on a sticky somewhere.
weird
Its not spyware and is normal to see running. This is a little about them.
Windows On Windows (WOW) Execution Support Process that provides support for 16-bit Windows applications together with ntvdm.exe. The service is started by NTVDM, which starts every time you run a 16-bit program.
The MOD file format is a music file format composed of sound samples in digitized format, arranged in certain patterns to create a song.
