WPA2-PSK
buffheman
Is this a common encryption? My network just changed to this, and I don't think any of my hardware is compatible. I have a Dell laptop that I got a few years ago, and a Belkin MIMO G+ wireless usb adapter for my desktop, neither of which will connect due to incorrect encryption type. But when I got to properties, AES and TKIP are the only options for encryption type under WPA2-Personal.
The only way I can connect is with my old Linksys wireless adapter. But it's too cruddy to pick up my weak signal. And even that registers it as a WEP encryption for whatever reason.
Or is PSK not even an encryption type? I am confused... I just want interent.
meionm
Are you running windows xp on it? If so you need to download update from microsoft for WPA2
Also since this is recent change, you might have it saved as something else on your computer. Right now you have wpa2 but you might have saved as wpa1 on your computer. Delete existing connection and connect again.
B
buffheman
Ok I will have to try that. I'm running Vista, and I went into properties and changed the security type and all that... I will just delete it though. Unfortunately, this conundrum forced me to come into work today...
meionm
Since you got vista, open connection manager. Click properties for selected wifi network. There you should be adjust type security. If you changed to wpa2 recently and name of the network remain same, computer still thinks that it is something else.
Also reboot router. Sometimes changes don't go in to effect right away.
petteyg359
Likes Popcorn
PSK isn't an encryption type, it simply means Pre-Shared Key (you have some set key like "MyNetworkPassword"), as opposed to RADIUS-type authentication, like SecurID cards, where each login requires a unique passcode. AES and TKIP are two different methods of applying the encryption. AES is generally considered more secure.
