x-fi or soundblaster?
moneyownzall
I've finally decided on getting a Logitech Z-5500 but im stuck when it comes to the sound card. The ones that I found on newegg that were realtivly in my price range are the Creative SOUND BLASTER X-Fi Platinum 7.1 and Creative Sound Blaster Audigy2 ZS Platinum. So which would be the best overall and pro and cons of each. I plan on using it for games and music and the occasional movie
Thanks
The X-Fi is going to give you better sound quality than the Audigy 2 ZS, I guess it boils down to how much you want to spend. I just upgraded to an X-Fi Fatal1ty from an Audigy 2 ZS, and there is heck of a difference in sound quality.
between the Creative SOUND BLASTER X-Fi Platinum 7.1, Creative Sound Blaster Audigy2 ZS Platinum, and Creative SOUND BLASTER X-Fi Fatal1ty FPS 7.1 the only price difference is 8 dollars
*edit*
the Creative Sound Blaster Audigy2 ZS Platinum comes with a 100 dollar rebate also, only 83 buxs :eek:
vote for x-fi since i have one, may as well invest your money in something that has a future in games ands what not, sure you can go Sb but hardly any games support it now.
The Audigy 4 Pro will give better sound quality than a low-end X-Fi, but doesn't have as many features as the X-Fi.
You can find an Audigy 4 Pro on eBay new for ~ $80. It comes with a pretty nice breakout box as well.
Obviously the X-Fi has more game support but the Audigy 4 Pro's DACs are the same as the uber expensive X-Fi Elite Pro/EMU-0404.
If your major concern is games, go for X-Fi.
EDIT -- Do not buy the Audigy 2 ZS. Waste of money imho.
hitbyaprkedcar7 said:
I have the X-Fi paired with my Z-5500's, and together it makes an unbelievable combination. I couldnt be any happier :)
same here, only with the Z5400s. my dads jealous because it sounds better then his $5000 home theater :)
