X2-3800 making 920PPD!
Mustanley
The P1809_Collagen is making 700PPD by itself!
This thing is folding at only 2.4GHz too.
I have that exact same p1809 but EMIII reports it as Amber core and worth 153 points, which is consistent with Psummary page. I think your EMIII is just confused.
Yes. I would be sure to download the latest protein data file from the Electron Microscope III download page. If that does not work, sometimes old wudata files get left behind from the previous unit in your client folders and may need to be "cleaned" manually to get things to register correctly. Your client was probably working on a p24XX Gromacs (600pt) previously and then downloaded p1809 Amber (153pt) but EMIII got confused on starting the new Amber.
Code:
[02:22:42] Folding@Home PMD Core
[02:22:42] Version 1.03 (September 7, 2005)
[02:22:42]
[02:22:42] Preparing to commence simulation
[02:22:42] - Assembly optimizations manually forced on.
[02:22:42] - Not checking prior termination.
[02:22:42] - Expanded 82325 -> 557656 (decompressed 677.3 percent)
[02:22:42]
[02:22:42] Project: 1809 (Run 4, Clone 507, Gen 42)
[02:22:42]
[02:22:42] Assembly optimizations on if available.
[02:22:42] Entering M.D.
[02:22:49] Protein: p1809_Collagen_POG10new_refolding
[02:22:49]
[02:22:49] Completed 0 out of 500000 steps  (0)
[02:35:11] Writing local files
[02:35:11] Completed 5000 out of 500000 steps  (1)
[02:47:31] Writing local files
[02:47:31] Completed 10000 out of 500000 steps  (2)
[02:52:45] Writing checkpoint files
[02:54:17] - Autosending finished units...
[02:54:17] Trying to send all finished work units
[02:54:17] + No unsent completed units remaining.
[02:54:17] - Autosend completed
[02:59:52] Writing local files
[02:59:52] Completed 15000 out of 500000 steps  (3)
[03:12:15] Writing local files
[03:12:15] Completed 20000 out of 500000 steps  (4)
[03:22:48] Writing checkpoint files
[03:24:40] Writing local files
[03:24:40] Completed 25000 out of 500000 steps  (5)
Hmm, dunno what to think then... definitely an amber core after checking.
You're making 177ppd on the p1809. EMIII foul up. Go into the work directory and delete the files with wu #s not related to the current WU and EMIII will report correctly.
