X800 Xt
Oxide
Ireland
I am wondering if my X800 Xt will fit in a asrock K7VT2 series motherboard, any users os this board have an idea. I tryed their tech support but it was crap :(
I don't know anything about that board but if it has an AGP slot then yes it will work. All newer boards have an AGP slot; this is the top slot above the pci slots.
methinks you need to overhaul your computer :p. your X800 will be bottlenecked by some of the older parts in that system.
what are your system specs? before dropping $500 on a state of the art video card, anything else you need to bring up to date?
from the way he said it, it seems he already has the card, but i agree he needs to update his components to see that card perform well.
The motherboard is about 1 year old, but if i need a new motherboard for this system, can i get some advice on a new motherboard? i have about $250-300 to spend. My rig has a 40gb hd, 512 ddr and a amd 2400+. the motherboard should be able to accept ecc buffered ram
