hey all,
i just got a X800XT to try and keep my system going a little longer till i can upgrade it. the problem is that when i try to run 3dmark 03 or 06, it reboots before it finishes. In 03 it finishes wings of fury fine, and when it starts test 2 it blue screens and resets, and in 06 it gets most of the way through and just resets. i don't think it is heat related because i played ut2004 for about an hour after each test failed, then took the card out remounted the heat sink with fresh as5 and boot up, same issue. i have tried 8.4 and 8.3 with no difference between them.
Any help would be appreciated!
thanks!
-Ichelo
thanks!
-Ichelo
