xbox 360 aftermarket component cables
pak
Tracy, ca
So I have tried 2 different sets of component cables for my 360 and both failed to work. One was a monster set and the other was a gigawire set. The gigawire set is a multi platform set and it worked on my wii.
My tv just says "not supported mode" I have tried different resolutions with no luck.
any ideas?
--pakk
Flurp
Washington
seems like a setting on your xbox may be wrong? you can adjust what format it sends out... RGB etc...
TheGreySpectre
I don't believe 1080p is supported via component I think you need a digital connection to support the HDCP encryption. Try setting your xbox to a lower setting and seeing if you can use it then.
pak
pak
Tracy, ca
I tried all different resolutions with no luck. This is really puzzling me.
hajalie24
Michigan
Most aftermarket cables for the 360 suck.
Try the real cable or an overpriced monster one. If your 360 has hdmi you can try using it to make sure it is the cable that is wrong and not the xbox.
pak
pak
Tracy, ca
I got a set of S-video cables and they work. I have no idea what was going wrong with the component cables I had.
pak
pak
Tracy, ca
I wanted another set to be able to move my xbox between two TV's more easily. Yes. I tried all 4 different TV's.
