- Nov 3, 2008
Which is better for playing media streamed from a PC media server. I already stream to my PS3 and it is great but for the money I cant see buying another for streaming play if the 360 is just as capable for 100 less.
ps3 sure its very good and have agood graphics
but i have anuther sugest
why you dont buy ps2 if you have small problems with $ $
take care of your self
ATM I am going to use my current PS3 for one room as I don't need an HTPC next to a ps3 anyway Might look into the XBOX capabilities a little more in depth.
The 360 is obviously going to be inferior as far as the different types of media you can play.
Now a USED ps3 won't be much more expensive than a new 360 arcade... and they've got downloadable games every bit as child friedly as what comes with a 360 arcade.
You also said your home wasn't wired-up...
Well the PS3 has a built in wireless adapter and the 360's adapter is a hundred bucks.
That would be the end of the story for me.
You could easily stream media, even between floors, with the built-in wireless adapter of the second PS3.
Hell... you could probably do all that from the first PS3 if you have some sort of receiving device on the other floor.
